-   CPU's and Motherboards (https://www.hardwarecanucks.com/forum/cpus-motherboards/)
-   -   Whats the diffrence between a 975-965 I7? (https://www.hardwarecanucks.com/forum/cpus-motherboards/22263-whats-diffrence-between-975-965-i7.html)
Overclocker~4.1 August 24, 2009 11:38 PM
I am window shopping as I have abit of money coming my way, and i was looking at these procs. I can't seem to see the diff between them other then Ghz bump... is it a slightly diff core or revision?
shayan288 August 24, 2009 11:52 PM
I believe the 975 overclocks better than the 965. But IMO its DEFINATELY not worth the price difference and if I had the money I would just save the extra bucks and get a 945 or even a 920, for they ALL overclock really well.
Overclocker~4.1 August 25, 2009 12:05 AM
I'm a sucker for the unlocked multiplier. *points to his current cpu* but your right, the extra money isnt worth it.
Linus August 25, 2009 12:10 AM
975 is also D0 stepping.
Overclocker~4.1 August 25, 2009 12:17 AM
That is what makes it a little better at OC'ing. yes?
bojangles August 25, 2009 07:22 AM
D0 is a better wafer yield and has some revisions in power distribution in the chip. You should see some gains in overclocking with these D0 chips, but not too much to really worry about C0 vs. D0.
Overclocker~4.1 August 25, 2009 02:10 PM
In other words, the extra $300 for a slightly better stepping of the original chip is simply not worth it.
MpG August 25, 2009 03:05 PM
Well, you can also make the argument that the extra $700 over a 920 isn't worth it either, especially if you won't be using anything stronger than water to cool it.
Sagath August 25, 2009 07:29 PM
Yup. I would say 920 and oc it. You'll hit 965/975 speeds (and then some) anyways. ANYTHING higher then a 920 is dumb to buy if you plan on OC'ing. JMO tho.
Overclocker~4.1 August 25, 2009 09:02 PM
Good points.
