-   -   Switched Mobo... WTF CPU Temp Difference...? (http://www.hardwarecanucks.com/forum/cpus-motherboards/22047-switched-mobo-wtf-cpu-temp-difference.html)
shayan288 August 18, 2009 04:34 PM
Hi there folks,
I had recently switch my motherboard from a evga 780i (it died) to a Gigabyte EP45 UD3P and I hear that the ud3p would generally run cooler than my previous. Now the motherboard runs cooler that before, but for some strange reason, I am now idling my q9550 (at 3.8ghz) at 43C and LOADing at liek 65C (OCCT) (this is 1.35v vcore in BIOS) while when I had my old motherboard, I was idling at like 35c and LOADing at like 55C. Some people say that it takes a while for the thermal paste to liek reach its maximum cooling ability so Im sure hoping thats the reason (I just finished building it today) So, does anybody have any reasons or explanations for this???
Thanks in advance.
s288.:thumb:
jay51 August 18, 2009 04:36 PM
maybe try remounting heatsink
shayan288 August 18, 2009 04:38 PM
Im really sure its mounted really well and plus if iit wasnt Id probably get way higher temps, right? Any other ideas?
enaberif August 18, 2009 04:39 PM
uh its called nvidia chipsets.
They run stupid hot :P
Intel is where its at.
element291 August 18, 2009 04:40 PM
possibly new mobo is putting out different voltages than the other mobo?
shayan288 August 18, 2009 05:02 PM
UD3P is NVidia chepset...?:bleh:
enaberif August 18, 2009 05:10 PM
Wrong.
Gigabyte = Intel
780i = Nvidia
Nvidia = hot = failing northbridge = failing memory controller = dead ram/mobo
shayan288 August 18, 2009 05:17 PM
No man, I replyed saying that because In the thread I posted that my NEW UD3P motherboard seems to be causing my cpu to get higher temps than my 780i. I am completely aware that ud3p is not a nvidia chipset. I just responded with that to make you like maybe read the first post again because it sounded liek you were mistaken.
enaberif August 18, 2009 05:38 PM
OOPS! haha.
I did, my bad.
As someone stated check your voltages.
shayan288 August 18, 2009 06:32 PM
Originally Posted by enaberif (Post 241762)
Wrong.
Gigabyte = Intel
780i = Nvidia
No I said that because I feel that yo have not read the first post correctly and that my NEW motherboard is the ud3p and I am completely aware that is an intel chipset and not an nvidia chipset.
