Old August 17, 2009, 01:20 AM
Default E8400 and 64-Bit OS
Will Vista 64 work with the Core 2 Duo E8400 ?
Old August 17, 2009, 01:31 AM
Neolithium_Wpg's Avatar
You betcha. I have Vista x64 with my rig.
MacBook Air 13" (2011) | Blackberry Bold 9900
A Veteran, whether Regular Force, Reserve or Retired- is someone who, at one point in their life, wrote a blank cheque made payable to the Dominion of Canada for an amount of "Up to and including my life"
-Author Unknown
Old August 17, 2009, 08:28 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Vista 64 will work with pretty much every setup
Old August 17, 2009, 08:53 AM
See if you can still download win7RC 64 bit. It is free, for now anyway, if MS has not turned it off.
Old August 17, 2009, 09:30 AM
Shadowmeph's Avatar
since I bought the 8400 almost every OS is 64bit
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old August 17, 2009, 11:39 AM
Have any of you had the nvlddmkm.sys driver problem with your 64-bit Vista and E8400.
With my current CPU "a Pentium-D 930 at 3.0 GHz" Have always had that driver problem with my Vista 64. That's why I'm currently using my XP 32-bit OS
Old August 17, 2009, 11:41 AM
Can't say I have had any issues here.
-Author Unknown
Old August 17, 2009, 11:43 AM
64BIT OS for sure that way you can take advantage of more RAM etc..
Comp1 (Mine) : ASUS Sabertooth, i7 2700K, 8GB 2133 GSkill, XFX 7970 DD, OCZ Vertex3 240GB, OCZ Vertex3 480GB, 600GB VelociRaptor, Corsair 1000HX, Cool Master Cosmos 2
Comp2 (Wife's) : Intel DP67BG, i7 2600K, 8GB Corsair Vengeance 1866, 1TB HD, 2TB HD, Sapphire 7950 OC, Corsair 950W, HAF 922
Comp3 (Kids) : ASUS P8P67 Pro, i7 2700K, 8GB 1866 GSkill, Sapphire 7970, Crucial M4 120GB, OCZ Vertex3 240GB,1TB WD Black, Antec 850W, Antec 1200
Old August 17, 2009, 12:23 PM
Eldonko's Avatar
That is your GPU driver mate, nothing to do with the CPU. I would uninstall and then update the driver to the latest you can get on Nvidia's site. Ensure you DL the x64 version.
Old August 17, 2009, 02:51 PM
A while ago I did a fresh Install of my Vista 64 and got all the latest 64-Bit drivers. And the Video driver problem nvlddmkm.sys always was there. I also search the net for Solutions to fix the problem. And tried them all and nothing fixed it. That's why I did a format and installed my Windows XP instead.
P.S. I was thinking the problem was caused by Installing a 64-bit OS while using a 32-bit CPU.
Any benefits of installing Windows 7 64 bit vs 32 bit? HoTiCE_ O/S's, Drivers & General Software 20 November 5, 2009 04:35 AM
Maybe a Bit Much To Ask El_Fiendo Off Topic 14 June 30, 2009 02:46 PM
XP Pro 32 bit - Upgrade too Vista Ultimate 64 bit Maxtor O/S's, Drivers & General Software 5 April 13, 2009 03:34 PM
64 Bit Vista Ultimate and Office Ultimate 32 Bit tyreman O/S's, Drivers & General Software 5 March 22, 2009 04:54 AM
Vista Home Premium 32 bit to Vista Ultimate 64 bit 334th_Frenchie O/S's, Drivers & General Software 4 September 9, 2008 07:45 PM
