Old August 16, 2009, 07:11 PM
Trial Member
Question Upgrade Question
I have a Asus Commando motherboard and a Intel Core 2 Duo E6600 2.40ghz cpu and I would like to upgrade from there.
A friend suggested I get a P5N-D motherboard. Does that sound good?
As for a cpu I have no idea.:help:
I will be upgrading to a eVGA GTX 275 at the same time as I upgrade my motherboard and cpu.
My current setup is:
case is antec tower 900
# Operating system:Windows 2.5.1.2600 (SP 3)
# CPU type:Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
# CPU Speed (GHz):2.419
# System memory (GB):1.999
# Graphics card model:NVIDIA GeForce 8800 GTS
Thanks!,
Boing
Old August 16, 2009, 08:20 PM
JD JD is offline
Much better off with an Intel P45 chipset, unless you absolutely require SLI support. And if you do, I'd probably go with an EVGA motherboard then.
Something like the ASUS P5Q-E or P5Q-Pro or Gigabyte GA-EP45-UD3P or UD3R would be my choices.
Tags
asus commando
Best way to go to upgrade. Bubbzilla Video Cards 17 August 11, 2009 06:14 PM
Videocard upgrade question r0bc Video Cards 8 April 18, 2009 12:13 PM
Looking for an upgrade Beermaster Video Cards 10 January 13, 2009 03:40 PM
upgrade Boogotop CPU's and Motherboards 6 December 20, 2008 12:41 PM
New PC upgrade Cobra New Builds 11 August 6, 2008 10:02 AM
