Old August 7, 2007, 02:48 PM
Default Tuniq Tower 120 or Coolermaster GeminII with 2 x 125CFM Fans..?
If I do take the GeminII, I will use 2 x 120mm, 2800rpm, 125CFM fans
Tuniq Tower 120... Tuniq Tower 120 CPU Cooler (Socket 478/754/939/940/AM2/LGA775)
Coolermaster GeminII... Coolermaster GeminII Heatsink (Socket AM2/754/939/940/LGA775)
Fans...... YS-TECH FD1238 120mm Fan - 4 Pin
I dont care about noise, just the best cooling vs price
Old August 7, 2007, 03:08 PM
CMetaphor's Avatar
Quadfather
Id say go with the geminII. the tuniq tower has better reviews normally, but thats when compared to a geminII that uses silent/low rpm fans. With those two giant 125 cfm fans on there you should get an awsome overclock out of it too and NOT NEED any additional NB/RAM cooling (assuming you have a fairly decent NB heatspreader already). Have fun!
Old August 7, 2007, 03:54 PM
Mibs's Avatar
I saw the GeminII in CPU magazine a couple months back, that thing is huge!
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Old August 7, 2007, 03:56 PM
CMetaphor's Avatar
Quadfather
That it is...
Air Cooling FTW!!! hehe.
Old August 8, 2007, 07:58 PM
lowfat's Avatar
If the prices are similar the Tuniq is the better performer. Although there is definitely better out there.
Tuniq Tower BALISTX Air Cooling 11 February 14, 2008 07:53 AM
Intel E2160 @3.6Ghz, 1.6V using Coolermaster GeminII keenan CPU's and Motherboards 2 August 11, 2007 08:15 AM
DS3 with Tuniq Tower 120, need suggestions for a northbridge cooler... paolo CPU's and Motherboards 0 June 10, 2007 10:30 PM
