Old August 10, 2009, 01:27 PM
JD JD is offline
Default Difference between EP43-UD3L and EP45-UD3L
Well I've been looking at both to use as a value overclocking board for an E6600. Probably 400FSB, maybe a bit over depending how cooling goes (either the Hyper 212 or Corsair H50).
GIGABYTE - Product - Motherboard - Specification - GA-EP43-UD3L (rev. 1.0)
GIGABYTE - Product - Motherboard - Specification - GA-EP45-UD3L (rev. 1.0)
I can't seem to really find anything majorly different between them. Other than the obvious different heatsinks and chipset. Not like either has Crossfire or RAID support. Only thing I can find is that the P45 *might* overclock higher, though 400FSB should be doable regardless as it's "supported" on the P43 via OC by Gigabyte.
Only main thing is the $20 difference between them and well saving money is always nice.
Old August 10, 2009, 01:37 PM
geokilla's Avatar
P43 chipset is a budget chipset, while the P45 is like mainstream if my facts are correct. I'd just go with the P43.
Can the E6600 hit 400FSB?
Old August 10, 2009, 01:39 PM
gingerbee's Avatar
I don't even have to look buy the p45 and forget the p43 ^ it's a budget board
Old August 10, 2009, 01:49 PM
e6600 is good to about 3.4 maybe 3.6 if you have a good chip.
So 400fsb MAYBE possible but your better off aiming for 3.4
Old August 10, 2009, 02:55 PM
JD JD is offline
I know it's possible as it's my old chip. It can get up to 4GHz and into Windows, though not totally stable
Old August 10, 2009, 04:08 PM
Pike's Avatar
I'm running the EP45-UD3L and its a solid board....took my E8400 to 4ghz on air.
"It is no measure of health to be well adjusted to a profoundly sick society" - J. Krishnamurti
E8400@3.0Ghz - Gigabyte EP45 UD3L - OCZ 4GB PC2-8500 DDR2 - Sapphire 5750 512MB - 5 Seagate HD 500GB - Plextor 712A DVD-RW - CM HAF 922
Old August 11, 2009, 06:05 PM
JD JD is offline
Well I just grabbed a P43. Hopefully it does the job.
Old August 23, 2009, 08:26 PM
JD JD is offline
So far the EP43-UD3L has been perfectly fine. Running 333FSB without a hitch, haven't got around to pushing it to 400FSB yet though.
Also runs OSX nicely too, needed to find drivers for the onboard sound and NIC but it was pretty simple so everything works now.
Old August 24, 2009, 05:03 AM
gingerbee's Avatar
try for a big overclock a lot of reviews said the board has problems overclocking that's why i said get the p45
Old August 24, 2009, 08:44 AM
geokilla's Avatar
OSX?! How'd you do that?!
Have fun with that board =)
Asus P6T ... What's the difference? Bones CPU's and Motherboards 6 February 27, 2009 10:24 PM
whats the difference? jay51 Display Units 0 January 27, 2009 10:45 AM
whats the difference between these two? Zippoh RAM 3 November 3, 2008 12:33 AM
What is the difference? akbg Storage 5 October 16, 2008 04:51 PM
