**pc specs = my signature / profile**
I wanted to overclock my E7200 (2.53Ghz) to obtain a decent speed, but not crossing the boundaries, so that I can use it 24/7 easily and not have to pay twice the bill on energy.
Please
tell me if I missed something or if I can do more!
1.The Steps:
a) moved the jumper on my mobo from 1066 fsb to 1333 fsb, as advised in the manual for a better OC. There is also a move to 1600 fsb for more speed. I don`t know if I crossed the line and if I should set the jumper to 1600. (
b) mods:
CPU Frequency - 337 ****standard
was 266
PCIE - 100
RATIO CMOS (multiplier) - 9.5
Enhance Halt State - Disabled
CPU Thermal Throttling - Enabled
No-Execute Memory Protection - Disabled
Speed-Step - Disabled
C-State - Disabled
CPU Voltage - 1.200v ****standard
was 1.125v
RAM Voltage - 1.96v @ 4-4-4-12 / 809mhz ****standard
was 1.90v @ 4-4-4-12 / 800mhz
[should i make any ram modifications like timings, voltage, frequency?]
RealTemp after 1h: 50*C IDLE @ 27*C Room Temp
CoreTemp:
VID on both cores: 1.1375 / M0 Revision
c) pics:
