Old August 8, 2009, 07:07 PM
Wurmer's Avatar
Default E 8600
Ok here is,
I have just received my new E 8600. I have installed it and a Xigmatek 1283 recuperated in another rig. Thing is, there is a pretty big difference between the two core temps. Core is showing 20 C which is a bit low since ambient is 21 but core one is showing 33c which is weird. Something is wrong with that much of a difference between the cores. I have reseated my heat sink using a bit less thermal paste but the reading are the same. Should this be RAM or is there any other explanation ? I am getting the same temperature readings from Core temp and PC Wizard.
Old August 8, 2009, 07:10 PM
3.0charlie's Avatar
Probably a stuck sensor. Use Prime95 to load and see if the stuck core changes temp.
Hydro-Quebec is salivating...
Old August 8, 2009, 07:41 PM
Wurmer's Avatar
Ok after 20 minutes of prime, both core are showing 36-37 C. I am not sure what it says but one thing is for sure core 1 doesn't seem to be stock at 30.... What now ?
Old August 8, 2009, 07:43 PM
3.0charlie's Avatar
That sensor is stuck at a minimum of 30ish degrees. Nothing you can do about it, Intel refuses RMAs on those. It won't damage the chip either.
Old August 8, 2009, 07:58 PM
Wurmer's Avatar
Well it's not like 33C is alarming but I was just wondering. I'll probably keep it and see what happens. As far as loading temperature, it seems to work ok since it pretty much shows the same temp as core zero. If I ever decide to over clock I don't think that will be too dangerous. It's not like the sensor is not working but it's not working normally as far as idle temps is concern. What do you think ?
Old August 8, 2009, 08:03 PM
3.0charlie's Avatar
As I said, it stuck at a minimum temp. Once you load the chip, it will report correct temps once it passes that threshold. Keep it.
Old August 8, 2009, 08:05 PM
gingerbee's Avatar
+1 to 3.0charlie
Old August 8, 2009, 08:07 PM
Wurmer's Avatar
OK thanks, that's what I'll do.
BTW, I have just noticed your HTPC setup, I have something extremely similar and it works great so far.
Old August 8, 2009, 10:47 PM
rjbarker's Avatar
Stuck Sensors on Wolfdales (while at idle) is extremely common as has been pointed out.....no worries at all!
Firestrike Extreme: 21.452
MARK 11: 32.530
[WTB] vidcard 8600 or higher cmac79 Buy/Sell & Trade 3 June 12, 2009 01:07 PM
xfx 8600 GT Fatal1ty - Opinions? ShinseiKen Video Cards 8 August 14, 2007 05:47 AM
8600 Series BALISTX Video Cards 32 May 16, 2007 08:12 PM
Looking for more 8600 reviews? Babrbarossa Reviews & Articles from the Web 1 April 18, 2007 12:06 PM
NVIDIA 8600, 8500 reviewed!: Anandtech Babrbarossa Reviews & Articles from the Web 3 April 17, 2007 10:09 PM
