Originally Posted by bojangles As long as they're the same model you can splice them together, however only use one RPM wire to the motherboard connector. You don't want to put mixed signals in there. Just splice the + and - leads to each fan and you should be fine. As long as the fans aren't high powered (aka Deltas and San Aces), there shouldn't be a problem. |
All of my fans are yates and they plug into each other . well this is good new to me then I was alittle worried about using to much juice hehe
