Old August 2, 2009, 01:31 PM
Another decent review by my favourite reviewer. Very few reviewers take the time to measure the actual voltages using a multimeter from the read points. It's an added plus to have pictures showing exactly where the read points are, so you can measure them yourself.
Good to know voltage regulation is nice with this board. I've always assumed because of it's low amount of power phases, it had mediocre voltage regulation.
After your review I can confidently say this is the best value AMD board on the market that doesn't have built-in video.
Old August 3, 2009, 05:31 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Thanks for the compliments, I am sure that MAC appreciates then as he sure did put alot of time and effort into this review.
Old August 11, 2009, 10:24 AM
donimo's Avatar
I just purchased this board and a 7750 BE to make a budget/possible fun combo. Couple problems though, NCIX won't let you request a rev 2, which means I of course got a rev 1
but my temp 3 is 80-83*C!!!!!!!! whats up with this? I have decent temps for everyhting els, and more than enough airflow to get this down (120mmblowing right across the mobo, 2x120 exhaust fans...) anyone else see this?
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old August 11, 2009, 11:24 AM
Read somewhere that DC is shipping the rev 2's
Old August 13, 2011, 12:30 AM
I currently have a TripleCore AMD Phenom II X3 710, 2600 MHz (13 x 200) with it. Anyone know if I can upgrade the CPU to the newer ones? My Mobo is v1.0. Other than that, the board is great, no complaint.
Old August 13, 2011, 12:33 AM
supaflyx3's Avatar
yes you can.
Old August 13, 2011, 01:10 AM
MAC's Avatar
MAC MAC is offline
Associate Review Editor
As stated above, yes you can, everything up to the flagship Phenom II X6 1100T is supported.
Request Review: Gigabyte MA770-UD3 jcmaz Reviews & Articles from the Web 14 March 24, 2010 06:20 AM
Gigabyte EP45-DS3R P45 motherboard review comment thread Eldonko CPU's and Motherboards 23 December 12, 2008 07:35 PM
Gigabyte GA-EP45T-Extreme Motherboard Review Comment Thread 3oh6 CPU's and Motherboards 28 October 22, 2008 02:58 AM
Gigabyte GA-EP45-DQ6 Motherboard Review Comment Thread MAC CPU's and Motherboards 15 September 2, 2008 09:51 PM
