<~----> CPU upgrade - Hardware Canucks
Old July 27, 2009, 07:48 PM
Default CPU upgrade
Greetings. My e6400 has served me well and is going to a new home soon. I'm looking for a quad. This will be my final 775 cpu purchase. It will have to last me awhile. My budget will be between $125-$200.
What would you all suggest for best bang for the buck without breaking the bank? I will more than likely be purchasing second-hand.
Thanks.
Old July 27, 2009, 07:56 PM
rapmaster's Avatar
there are a couple of Q6600 for around 150$ in the Buy/Sell & Trade section.
Quando omni flunkus moritati
Old July 27, 2009, 08:13 PM
Shadowmeph's Avatar
I haven't owned a quad core and the reason being is that I don't really think that I need one the run ( from what I have read and heard) hotter then most dual cores I have been using my e8400 for just over a year and it works great I have never had any slowdowns that involve the cpu or for that matter any slowdowns period , so personally I think that unless you do allot of OCing and multi tasking that you really don't need a quad core. I do a fair amount of gaming and simple video editing I can unrar very large files download large files video edit and play Starware KOTORs at the same time with out any problems. but the decision is yours . when I do finally upgrade it will be I7 or I5 core something like that.
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old July 27, 2009, 09:42 PM
JD JD is offline
Q6600 or a Q8300. About all you'll get in that price range.
The Q8300 edges out the Q6600 performance wise, though it'll probably cost you more like $200. If you have plans to OC and have decent cooling, Q6600 is probably your best bet. If you're running stock, go with the Q8300 since it'll run cooler and it's a bit faster than a Q6600 at stock.
Old July 27, 2009, 09:50 PM
rjbarker's Avatar
+1 What jdrom said...whats goign to hold you back is your budget....the Q9550 would be great, but I believe they're going for around $350....
Old July 27, 2009, 10:35 PM
shayan288's Avatar
I hope that was a typographical error.. :P It costs around 250 in stores.
The 288
Q9550 E0 stepping @ 4Ghz
Gigabyte EP45 UD3P
G.Skill pc2 8500 1066mhz RAM
Western Digital 250gb
Antec 1200
XFX HD5970
Steelseries Xai Laser Mouse
Windows 7 Ultimate x64
Old July 27, 2009, 11:15 PM
rjbarker's Avatar
Yeah I just realized that....I'm thinking of selling my E8400 and replacing it with a Q9550...so checked the prices and whooaa...they've come down in price considerably since I was last looking at them....
Old July 28, 2009, 01:49 AM
I'm going for the Q8XXX or 9XXX for the 1333fsb. I may get lucky on ebay.
Old July 28, 2009, 02:01 AM
Or very unlucky...
Old July 28, 2009, 02:36 AM
If you're alluding to the fact that I may get a dead cpu, I dont buy unless the person has near 100% positive feedback, more than 25 transactions under his/her belt and a DOA guarantee. I have never had a bad experience buying or selling pc parts on ebay.
Upgrade Laptop CPU??? jcmaz CPU's and Motherboards 10 July 14, 2009 07:32 AM
CPU upgrade micul New Builds 4 July 7, 2009 07:13 PM
Best CPU upgrade??? Delavan New Builds 11 April 2, 2009 07:41 PM
upgrade cpu / memmory?? ultra2 New Builds 12 April 1, 2009 10:59 AM
Cpu, Gpu or what? upgrade? phil3_66666 CPU's and Motherboards 12 March 14, 2009 05:54 PM
