  #21 (permalink)
Old January 30, 2007, 03:34 PM
sizerkozak's Avatar
Originally Posted by Forge View Post
That is an impressive rig, thanks for the pictures it would be difficult to visualize the great work you've done without them.
your welcome !!
and thanks :)
QX6700
ASUS P5N32-E SLI
BFG 8800 GTX
OCZ DC 2048MB PC8500 1066MHz DDR2 SLI
RaptorX 150GB 10K RPM
Three LGL1919S & 3HeadToGo
BFG 1000w
-20C Liquid Chiller
Rig Pics and Stats
Water chiller project
Monitor mod
  #22 (permalink)
Old January 30, 2007, 09:28 PM
Misoprostol
Guest
Posts: n/a
my pump is not submersible. It's the one that Drewmeister recommends in the guide that you probably followed to make this chiller.
I don't see it anywhere, but I'm probably not the only person to wonder this... What water block are you using?
  #23 (permalink)
Old January 31, 2007, 06:26 AM
sizerkozak's Avatar
Guide? what guide?
I used a danger den block
QX6700
ASUS P5N32-E SLI
BFG 8800 GTX
BFG 1000w
-20C Liquid Chiller
Rig Pics and Stats
Monitor mod
  #24 (permalink)
Old February 24, 2007, 01:19 PM
Misoprostol
Guest
Posts: n/a
Hey it's an older thread at this point, but a couple words of caution:
I used a Danger Den TDX Universal. Basically it has a lucite top covered by a metal mounting plate. After about a month of using my chiller it started to develop little micro cracks in it. It never leaked, but I pulled it once I noticed. I've pulled it from the chiller and switched to a Swiftech APOGEE for now. I'll let you know if I have better results once I get that set up.
Don't use Arctic Silver 5 for sub cooling. It becomes far less effective once you reach about 0C I think was what I heard. Ceramique is the TIM of choice for most low temperature projects that I've heard of.
  #25 (permalink)
Old March 12, 2007, 04:57 PM
cyberspyder's Avatar
I've seen this somewhere...any chance you posted at XS?
  #26 (permalink)
Old March 13, 2007, 04:37 AM
Patriote's Avatar
Lo0L! I was thinking the same! Yeah i think it was on XS.
Anyway, thats just awesome. I bet it's quite noisy under your desk huh ?
- Asus P8Z68-V PRO
- Intel I5 2500k @ 4.5Ghz
- Asus Geforce 580GTX DirectCUII Fermi
- 16GB Corsair Vengeance Low Profile
- Ultra X3 1000 Watt
- Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
- Corsair Vengeance 1300 Gaming Headset
- Crucial M4 SSD 128GB \ WD Caviar Black 1TB
- CoolerMaster 690II Advanced
- Dell UltraSharp 24''
- Noctua NH-D14
  #27 (permalink)
Old March 13, 2007, 06:09 AM
sizerkozak's Avatar
yupper its at XS as well !!
And you know its actually pretty quiet under the desk ....since its mounted in an isulated box...only a bit of fan noise comes thru
QX6700
ASUS P5N32-E SLI
BFG 8800 GTX
BFG 1000w
-20C Liquid Chiller
Rig Pics and Stats
Monitor mod
  #28 (permalink)
Old March 13, 2007, 06:26 AM
Patriote's Avatar
Sweet! You should start to manufacture those things!
How far have you been able to Oc you QX6700 with that chiller ?
- Asus P8Z68-V PRO
- Noctua NH-D14
Tec water chiller using Apogee gt's kirk_d Water Cooling 1 February 25, 2008 01:36 PM
My First Ever Water Cooling Project zlojack Water Cooling 37 February 6, 2008 09:10 AM
Large project James_8970 HTPC Systems & Software 6 January 9, 2008 10:44 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 01:08 AM
BALISTX'S 939 Project BALISTX Case Mods, Worklog & Gallery 55 September 26, 2007 04:23 AM
