Old July 24, 2009, 04:58 PM
JD JD is offline
For the price the 9950 is going for new, around $150, it really isn't worth it IMO. Unless you can find one used for under $100, I wouldn't bother.
You can grab the Gigabyte GA-MA770-UD3 and Phenom II X3 720BE for $251.25 which would be a far better choice. And you could most likely reuse everything you have. So if you have $180, continue saving up another $100 and just do it right.
Old July 24, 2009, 06:01 PM
I would need DDR3 for the board but still, it's a good plan. I don't need a complete new system. I would want a new video card at some point, but I think the bump in CPU and RAM would do some good to prolong a new GPU.
I just priced a new 720, that board, 4GB of PC3-12800 RAM (would like to have headroom), and a new Coolermatser Scout case (I do want to keep my old parts in a case), at my local PC store (Canada Computers) and after tax it came to $585.29 which is pretty reasonable. I should be able to do that in 2-3 months if my hours at work hold steady or increase.
Asus M2N-E|AMD Athlon64 X2 6400+|Arctic Cooling Freezer64 Pro|2x OCZ2P8002GK|BFG GeForce GTX 260 OC|Seagate Barracuda ST31000340AS|Tagan TG700-U88 BZ|Antec 900|Windows Vista Business 64-Bit SP2/Windows XP Pro SP3|Samsung SyncMaster 245B|Razer Lachesis|Logitech G15
Old July 24, 2009, 06:35 PM
JD JD is offline
That's a DDR2 board. Moving to DDR3 has very minimal benefits right now IMO. You don't have to use DDR3 to use Phenom II CPUs.
Though I suppose if you can afford DDR3 RAM, since it has drop a ton in price, then it's not bad to get it. Then you'd want this motherboard: GIGABYTE GA-MA770T-UD3P. Note the "T" after 770 means it's DDR3.
Old July 24, 2009, 07:08 PM
That's actually the board that I was looking at. I thought the user I was quoting was mistaken. Yeah I would go DDR3 for future proof reasons, and I would go with the DDR3-1600 because it is cheap enough.
Old July 24, 2009, 09:09 PM
grinder's Avatar
consider the X2 6400 the best proc your board can handle. I dropped a 9950 in my rig and it felt like a down-grade when gaming.. i actually LOST FPS.
One cool thing i did like about the 9950 vs the 6400 was ALT+TAB 'ing between games and windows desktop was WAY crisper on the phenom.
Old July 24, 2009, 11:00 PM
JD JD is offline
That would be because multitasking likes the 4 cores, where as games don't use 4 cores so it prefers the higher clocked dual-core.
Old July 24, 2009, 11:35 PM
Chilly's Avatar
OCVER CLOCK MAN, the OVERCLOCXJ MAN DOES OT ALLLL!!!! if yoyu overclokcm iotij will offset tyhe non awesomhness o the 8999550 becieasdee4 O am full of awesomnessQ!!@!!!
Old July 25, 2009, 12:15 AM
grinder's Avatar
tru that JD
amd 9950 @3 gig nasrott Overclocking, Tweaking and Benchmarking 10 November 21, 2008 04:25 PM
The New Amd 9950 thats right boyz! Dashock Rumor Mill 10 July 4, 2008 06:53 AM
AMD Phenom X4 9350e & 9950 Black Edition Review MAC Reviews & Articles from the Web 0 June 30, 2008 10:48 PM
Overclocking AMD 6400+ temps low351 Overclocking, Tweaking and Benchmarking 7 March 16, 2008 09:03 PM
Amd 6400+ Be Wamphyri CPU's and Motherboards 4 February 5, 2008 09:45 AM
