Old July 23, 2009, 09:30 PM
I've got an Asus Z8NA-D6C with two E5520s on it and 12GB (6x2) of DDR3-1333 Kinstrong ValueRAM, ECC but not registered (that'd double the RAM's price). If you're running VMs, I'd suggest going with 24GB of RAM over 12GB of RAM, in which case you're going to need registered ECC 4GB sticks. Not cheap though (I think $800 per). Or just try to get away with only 12GB (I know 12GB is fine for what I do right now, I'm light on VMs as I'm running this as my workstatin).
Old July 25, 2009, 11:58 AM
Chilly's Avatar
if you can swing for the X8DAi or the X8DAH+ do it, they are both great boards.
If your trying to save some money and only need 1 full PCIe 16x slot, look at something like the
Newegg.ca - SUPERMICRO MBD-X8DAL-i-O Dual LGA 1366 Intel 5500 ATX Dual Quad-Core Intel Xeon Processor 5500 sequence (Nehalem-EP processor) Server Motherboard - Server Motherboards
You can't go wrong with the SuperMicro boards.
[FS] Xeon E3110 Sniper Buy/Sell & Trade 5 November 27, 2008 06:24 PM
Intel Xeon 5140 vs E5410? Melodioso CPU's and Motherboards 4 June 15, 2008 08:17 PM
New Xeon vs Q6600 Nodscene CPU's and Motherboards 4 April 1, 2008 03:16 PM
xeon Rapid-X CPU's and Motherboards 17 March 9, 2008 05:07 AM
GamePC reviews Intel Xeon E5345 and X5355 quad-core processors Supergrover Reviews & Articles from the Web 0 January 5, 2007 07:28 PM
