Old July 21, 2009, 01:27 PM
Default Motherboard with onboard GPU
One of my friend ask me to built a computer for him. I usually built gaming computer for myself but he does not want that. He just want a computer for internet, music, burning DVD and watch movies. I was looking toward motheboard with onboard video but since I never used them I want to know if they are any good. He wants to keep his computer for couples of years. I was thinkg that with onboard GPU, he was alright for the next year or so and he could buy a good video card later on. With an AMD+ board, I could buy him a cheap CPU that he could upgradre in the future.
I was thinking of this board:
NCIX.com - Buy Gigabyte GA-MA780G-UD3H AMD780G ATX AM2+/AM3 2PCI-E Video Sound GLAN CrossFireX HDMI Motherboard - GA-MA780G-UD3H In Canada.
If you have any suggestion for another board, I'm ready to hear about it.
Thanks
Old July 21, 2009, 01:31 PM
Caldezar's Avatar
You've got the right idea for sure, although you could save your friend a few bucks by going with the GA-MA78GM. It's basically the same board, but mATX and with only one PCI-E slot, which won't matter to you anyway if you're using on board video. But if he wants to buy a single video card down the road, he still can.
Old July 22, 2009, 02:13 PM
thanks, do you think the onboard GPU will be good enought for windows 7?
Old July 22, 2009, 02:20 PM
Arinoth's Avatar
As long as you're not running Aero Theme, i think you should be fine
Here I am: here I remain
Old July 22, 2009, 02:24 PM
clone63's Avatar
Windows shouldn't offer anything that would stress a video card, but for high def content he might download a video card may need to be added. The 780g claims it can handle this though so perhaps not.
Old July 22, 2009, 02:42 PM
JD JD is offline
Should have no issues running Aero or playing back HD-content IMO. Make sure you get 4GB of RAM though.
If you can afford it though, get a 780G that has Sideport memory as well. That way the onboard graphics won't steal from the RAM. Something like this: NCIX.com - Buy Gigabyte GA-MA78GPM-UD2H AMD780G mATX AM2+/AM3 Sideport PCI-E SATA Sound GLAN HDMI Motherboard - GA-MA78GPM-UD2H In Canada.
Old July 22, 2009, 02:46 PM
Caldezar's Avatar
Agreed. I've seen this board with 4GB RAM and on board video running Vista 64 with Aero and playing video. Now, granted, I've not seen it attempt to play HD video, but it's designed with an HDMI out specifically for that purpose, so I'd have to say it'd be fine.
Old July 22, 2009, 02:52 PM
a 780G Motherbaord should be enough for win 7
imo
Old July 27, 2009, 03:49 PM
OJX OJX is offline
Thats insane. This board comes with an HD3200, it can play pretty much any valve game.
Aero theme would be of no problem whatsoever, at all!
Motherboard with onboard graphics? AbC-50 CPU's and Motherboards 9 May 5, 2009 06:03 AM
will my motherboard take my gpu's help dubbaz New Builds 3 January 9, 2009 10:26 AM
What motherboard has really good onboard sound? HermesĄ˘ CPU's and Motherboards 7 December 22, 2008 05:39 PM
Recommendations for onboard vid / 3 monitor Motherboard sswilson CPU's and Motherboards 7 April 7, 2008 02:45 PM
WTB: Socket 478 Motherboard and PCI GPU cb2222 Buy/Sell & Trade 2 March 23, 2008 10:52 AM
