  #41 (permalink)
Old August 6, 2007, 07:39 PM
3.0charlie's Avatar
350W wasn't enough. But that glitch with the ram slots really ^%#!!@# me off. Waiting for an answer back from NCIx.
  #42 (permalink)
Old August 6, 2007, 08:02 PM
belgolas's Avatar
Originally Posted by Somed00d View Post
You actually don't need the adapter. Just plug straight into mother board. Anyways powersupplies are getting cheap. Quality ones for around a $100-150.
  #43 (permalink)
Old August 6, 2007, 08:16 PM
3.0charlie's Avatar
That's what I did. Bought the Antec Trio 550W.
  #44 (permalink)
Old August 23, 2007, 12:12 PM
Smile Hello, my OC results
Hey guys, I read your forum and decided to give E2140 a try. What a great OC it was.
I am able to run the E2140 on STOCK COOLING, and STOCK VOLTAGE at 3.0 ghz. Core Temperature seems to stablize at 66C running at 100% using DVD Shrink. I have not tried orthos, don't know where to download it. But I think I'll run it once my Scythe infinity gets here.
Board: Abit IP35-E ($55 USD after rebate)
Mem: Crucial Ballistix ($65 USD after rebate) running at 5-5-5-15-29
Running at PC2-936 (memory was tested stable at PC2-1160 with CPU running at 2.32 ghz)
PSU: Cooler Master Extreme Power 550W ($0 USD after rebate)
Case: Cooler Master Centurion 532 ($30 USD after rebate)
CPU: E2140 ($55 USD)
I got a mini budget power house
  #45 (permalink)
Old August 23, 2007, 12:39 PM
turtletrax's Avatar
Prime95 Download - Softpedia
Try this. Easy to use and works like a charm.
"It's time to kick gum, and chew ass. And I'm all out of gum."
Dick Kickem
  #46 (permalink)
Old August 23, 2007, 12:48 PM
cool thanks alot. I'll try it. By the way, I just increased my memory divider to 1:1.5, and voltage to 2.3V
So now the RAM is running at DDR2-1124 and passed the mem86 test.
5-5-5-15-29 timing at DDR2-1124 for a pair of crucial ballistix pc6400
My superPI for 2M is 47 seconds
Oh yea, my computer doesn't have an exhaust fan, lol. But I can barely feel any heat.
  #47 (permalink)
Old August 23, 2007, 01:07 PM
My prime benchmark
  #48 (permalink)
Old August 23, 2007, 01:28 PM
Stress test, I think 71C is max I get. That's acceptable core temp right?
  #49 (permalink)
Old August 23, 2007, 01:36 PM
Default E2140 faster than a X6800
  #50 (permalink)
Old August 23, 2007, 03:58 PM
turtletrax's Avatar
71C is the limit and I would personally try to keep it under 65c. I realize that you probably will not reach these temps very often, if at all under normal usage, but the thermal envolpe developed by Intel must be there for a reason.
Also if you really want to see what kind of temps your Q66 is capable of run this...
Intel TAT - Overclock.net - Overclocking.net
Crazy load temps....
Dick Kickem
Overclocking help tzetsin Overclocking, Tweaking and Benchmarking 41 January 28, 2008 12:05 AM
Pentium Lives!! Pentium E2160 and Pentium E2140 Babrbarossa CPU's and Motherboards 4 June 4, 2007 04:25 AM
DirectCanada is amazing... Arcygenical Off Topic 11 May 11, 2007 05:43 PM
Amazing printer technology from Memjet Babrbarossa Press Releases & Tech News 5 March 23, 2007 12:11 PM
