  #21 (permalink)
Old July 30, 2007, 11:40 PM
Somed00d's Avatar
i wish my E6420 could clock that well lol..
1.55v for 3.2ghz at 54 deg on orthos with water cooling lol
Q6600 G0 @ 3.2ghz (965 chipset holding me back)
DFI Infinity P965-S
Gigabyte Geforce 8500GT
Buffalo Firestix FSX800D2C-K2G 2X1GB PC2-6400 CL5
OCZ XTC Active Memory Cooler
Seagate Barracuda 250GB SATA2
MCE Wireless Keyboard / Remote
Logitech X-530 Speakers
Swiftech H20-220 Water kit
Swiftech MCW30 NB Cooling
OCZ PowerStream 600W
  #22 (permalink)
Old July 31, 2007, 07:31 AM
Wankerfx's Avatar
Damn, the speed doesn't want to budge after 3.2ghz, even with 1.5V. I'll be getting water cooling soon and I'll push the Vcore to 1.6V.
[ER]
  #23 (permalink)
Old July 31, 2007, 08:02 AM
3.0charlie's Avatar
I know the feeling. System specs:
E2140 @ 3.0 - 1.43V
XFX 650i
Crucial Rendition PC2-5300 single 1Gb 4-4-4-12 1T
WD 80gb
ATI X300 PCI-e
Swiftech Premium kit, CPU only.
Major droop problem with that FSP 350W. I just may be asking a bit too much.
CPU-Z Validator Database
Dual-32m Prime testing stable, 18 hours Orthos stable. Idle temp. 28C (ambiant 24C), load temp 44C running Orthos.
Tried 3.1, unstable. 3.2 won't boot, even with 1.5V.
But that's good enough for me.
John
  #24 (permalink)
Old July 31, 2007, 08:38 AM
Wankerfx's Avatar
Thanks for sharing your results. What stepping is it? Mine is Q705A.
[ER]
  #25 (permalink)
Old July 31, 2007, 10:12 AM
3.0charlie's Avatar
Same. Q705A314.
  #26 (permalink)
Old July 31, 2007, 10:57 AM
Babrbarossa's Avatar
Amazing results! I have an e2160 here that's not happy at much over 2.84 (batch is L709A) on water- doesn't come close to my e4300. Based on my results I would have to recommend the e4300 as the better value, but it seems like people are having better luck than me with the e21xx's and much lesser results with the e4300s.
  #27 (permalink)
Old August 1, 2007, 11:41 AM
3.0charlie's Avatar
I think I spoke too fast. E2140 @ 3.0 I started folding yesterday morning and got EUEs in less than 1 hour. So I went back to Orthos - and after 21 hours it failed.... Memtest is fine for that single stick.
So I'm back to square 1 testing with Orthos @ 2.9, stock 5-5-5-15 1T timings and 1.37V. Still have that major Vdroop of .05V and a 12V of 10.2! Temps are beautiful though: 24C idle, load max of 45C using Speedfan.
I think I need a new PSU to replace that FSP 350W. It's just asking too much. I do have an Antec 380W (with more amps on the 12V+), but with 20 pins, not 24 pins.
John
  #28 (permalink)
Old August 1, 2007, 11:47 AM
Wankerfx's Avatar
I think you can use a 20 pin with a 24 pin slot, I'd have to check up on it.
a 12V of 10.2!
EEEEEEK!
[ER]
  #29 (permalink)
Old August 1, 2007, 03:42 PM
John
hahah 10v on a 12v line, thats far below the -/+5% drop hahah.
  #30 (permalink)
Old August 1, 2007, 04:12 PM
JD JD is offline
@3.0charlie, I think you should definitely look into a new PSU. Are you still running Windows 98 there?!? Looks a lot like it. Hopefully it's 2000.
Overclocking help tzetsin Overclocking, Tweaking and Benchmarking 41 January 28, 2008 12:05 AM
Pentium Lives!! Pentium E2160 and Pentium E2140 Babrbarossa CPU's and Motherboards 4 June 4, 2007 04:25 AM
DirectCanada is amazing... Arcygenical Off Topic 11 May 11, 2007 05:43 PM
Amazing printer technology from Memjet Babrbarossa Press Releases & Tech News 5 March 23, 2007 12:11 PM
