Old July 25, 2007, 10:23 AM
Jim's Avatar
Jim Jim is offline
Default oc results so far
Vcore in bios says 1.4125 don't know why it shows 1.392 in cpuz , mem volt 2.0 (limit is 2.1 as board version is 1.01 not 1.02 which has a 2.45 limit) , tried 380 x 8 wont boot even with volts at max of 1.45,core temp is no problem 36 idle 40 load room at 20. Any ideas how to go a bit further ?
thanks in advance
Shooter-Gigabyte GTX 660 Ti OC,G.SKILL Ripjaws 8 gigs DDR3-1600, Phenom 965 Black Edition @ 4.0,ASUS M4A88TD-M/USB3,Thermaltake XP-120,Corsair TX750,SAMSUNG BX2450,Win 7 64 Ultimate,A-40 MixAmp,Audio-Technica ATH-AD700,Speedpad n52
Every day use,HP somethin somethin 4 core,found at the dump,Xubutu all the way baby!
Old July 25, 2007, 11:15 AM
Fallen Folder
all the asus mobo's have vdroop ... I don't rely on V reported by cpu-z ... use asus probe instead.
Does it post at 380? but won't boot? If it won't post then memory is prolly stopping it.
You should run your mem at 1:1 with loose timings while trying to find the max cpu oc. Give the mem 2.1V. After you find cpu oc, then find your best memory speed & timings.
Have you tried fsb's in betwen 336 in your post and 380? Ususally best to work your way up to 380 in 10-20 increments, only bumping vc when needed.
Also, have you run any stress tests at 336? I like a 1m superpi and sandra bandwidth followed by orthos. Its best to establish the lowest VC that it will pass those tests at 336 before moving higher. Too much VC can sometimes hurt an OC depending on your chip.
Old July 25, 2007, 11:28 AM
Jim's Avatar
Jim Jim is offline
all the asus mobo's have vdroop ... I don't rely on V reported by cpu-z ... use asus probe instead. ok will do
Does it post at 380? but won't boot? If it won't post then memory is prolly stopping it. no post
You should run your mem at 1:1 with loose timings while trying to find the max cpu oc. Give the mem 2.1V. After you find cpu oc, then find your best memory speed & timings. not sure about that right now bios says ddr 700
Have you tried fsb's in betwen 336 in your post and 380? its at 350 all morning (sorry sounds noobish, cause it is)
Ususally best to work your way up to 380 in 10-20 increments, only bumping vc when needed. did in 10's every 30 or so had to ad vc to see desktop
Also, have you run any stress tests at 336? I like a 1m superpi and sandra bandwidth followed by orthos. Its best to establish the lowest VC that it will pass those tests at 336 before moving higher. Too much VC can sometimes hurt an OC depending on your chip.haven't done any of that , guess I better hu ? whys 336 important ?
btw is vcore to high as in damaging something ?
Old July 25, 2007, 11:56 AM
Jim's Avatar
Jim Jim is offline
now I know what you mean, those detailed memory settings in the bios...well so far I cant see any,lets hope their there, should be a screen like the second one but cant find it,ugh what to do ?
Old July 25, 2007, 12:03 PM
Fallen Folder
forget my ref's to 336 ... i looked at your cpuz shot too quick and the wrong number stuck in my head ! ... either that or it changed when you edited the post.
Your post now shows mem running 1:1 (it was 4:5 before your edit) - cpuz is the easiest way to confirm your bios settings on memory.
sustained high vcore for long periods will shorten the life of your cpu. I try to stay below 1.425 with my c2d/q's but i recall reading that the 4300's need a fair bit of vc.
I wouldn't worry too much about 1.45 for limited tests but your target should be to find the sweet spot where you get a decent oc without having to bump vc much. So start with low VC and work your way up including the stability tests. I have a dog of a e6600 that needs 1.425v to fold stable at 325x9 but the others get close to 400x9 on less than 1.4V
IMO there is no point in having a high oc that isn't stable for what the rig is intended for. If you only game, and the games never freeze or error then it is stable enuf. But I fold on my rigs so they need to be 100% stable with NO errors or the oc is useless to me. My final stability test is smp folding and it is not unusual for me to reduce the oc by 5-10 fsb that passed other stability tests just to get it error free when folding.
Old July 25, 2007, 12:12 PM
Jim's Avatar
Jim Jim is offline
thanks wil,greatly helpful as always,yea I'm just gamin with this so far battlefield hasn't missed a beat and never run better.i'll test it over night as you said to
Old July 25, 2007, 12:42 PM
3oh6's Avatar
Hardware Canucks Reviewer
i have no direct experience with the P5B-E but on the P5B-Dlx, memory timings are in the Advanced > Chipset > NB Config section. you have to change configure DRAM by SPD to disabled and then the list of available timings will show up. i am assuming it is the same or similar with all P5B based boards. HTH
Old July 25, 2007, 12:52 PM
Jim's Avatar
Jim Jim is offline
and there they are,not a word in the manual,good call,u da man
web pic not mine , no idea what any of it means , guess i'll be finding out
HWBot Results: Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 7 May 6, 2008 09:15 PM
New system, first OC results Spblue Overclocking, Tweaking and Benchmarking 10 January 5, 2008 12:43 PM
G0 vs B3 X3210 results Cptn Vortex Overclocking, Tweaking and Benchmarking 6 October 21, 2007 03:40 PM
Penryn Performance results Babrbarossa CPU's and Motherboards 3 April 19, 2007 07:10 AM
6000+ overclocking results Misoprostol CPU's and Motherboards 11 April 9, 2007 12:27 PM
