Old July 6, 2009, 11:48 PM
AmuseMe's Avatar
Default A Nice OCing Mobo for a Phenom II 955
Ambiant Room temp: 19C - 21C
Case: Antec 1200
CPU: AMD Phenom II 955
CPU Cooler: Looking
Mobo: Looking
GPU: Sapphire 4870x2
GPU Cooler: Arctic Accerlero XTREME
PSU: PC Power and Cooling Silencer 750w Quad SLI/Fire
RAM: Looking
Im looking for a nice motherboard to accompany a future Phenom II 955 BE. I want to overclock this thing a decent amount (3.8+) on air. So I'm looking for some mobos.
Right now, Im looking at the based on other posts MSI 790FX-GD70 based on other posts. Is this a good OCing board? It says something about 140w, and people are always talking about 180w, I have NO IDEA what this is, fill me in please
Also, whats the best air-cooler to put on it? Im really open to anything here. So please, help me out, and get me some good products.
I might crossfire down the road, but not sure. One 4870x2 works good for now
OH! Im also looking for some DDR3 Ram, most likely 1600MHz or something, only 6GB, with a cooler - for kicks.
Recap
1) Whats a good Mobo for the Phenom II 955
2) Whats a good cooler (air) for the 955
3) Whats a good 6GB kit (with cooler, if applicible, if neccisary) for the 955
Old July 7, 2009, 10:00 AM
AmuseMe's Avatar
Bump-o-rama
Old July 15, 2009, 07:01 PM
Default Overclocking board
well if u want to overclock the 955 well i would actually suggest the DFI DK 790FXB-M3H5 AM3 mobo. It, along with most other DFI boards, is a great oc'er
as for a cpu cooler, i kinda like the astek LCLC cooler, but there are some better air coolers as well. it all depends on how much u want to spend
and lastly, for ram, i would highly recommend the OCZ GOLD or OCZ PLATINUM DDR3 1600 kits, they have good timings and they are relatively inexpensive. great value. for a ram cooler, u can use OCZ's XTC cooler for any ram
hope this helps
Old July 15, 2009, 07:03 PM
o and here are the newegg canada links to the mobo and ram:
mobo: Newegg.ca - DFI LP DK 790FXB-M3H5 AM3 AMD 790FX ATX AMD Motherboard - AMD Motherboards
ram 4gb cuz amd only uses dual channel: Newegg.ca - OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model OCZ3P16004GK - Desktop Memory
Old July 16, 2009, 08:44 AM
Cowboy's Avatar
Best air cooler is without a doubt the TRUE...
But if you want a better OC, I suggest going for water cooling or getting a freezone elite (or even a boreas if you've got the coin)
Old July 16, 2009, 09:51 AM
sswilson's Avatar
I've got the MSI board and the OCZ 1600 plat sticks downstairs in boxes, but unfortunately I doubt I'll be able to get to them until next week or possibly next weekend in order to give you my impression(s) of the board.
I can say that it looks pretty damn good, but looks won't mean a damn thing if it doesn't OC well. :)
Wish I could offer you some advice on it right now, but if you're not buying for a couple of weeks I should be able to put up some numbers for you by then.
Old July 16, 2009, 04:55 PM
AmuseMe's Avatar
This is old now. The AM3 thing is probably not going to happen. I really dont need it all right now. Im going with a Q9550 (old, but fun)..
Old July 16, 2009, 05:35 PM
Cowboy's Avatar
oh
cool
thanks for the update.
Intel i7 920 or Phenom II 955? AmuseMe CPU's and Motherboards 30 August 13, 2009 05:00 PM
Best 955 mobo? bumfloss CPU's and Motherboards 13 August 11, 2009 12:16 AM
AMD Phenom II X4 955 BE. Good contender to i7? bojangles CPU's and Motherboards 40 June 28, 2009 01:16 PM
NCIX has the Phenom II 945 and 955 up snoosebum CPU's and Motherboards 5 April 22, 2009 11:16 AM
