Old July 6, 2009, 04:00 PM
Quad all the way... At stock clocks the mhz gap is pretty small and the Q9550 should overclock to the mid to high 3.x range while the e8400 will do 4+ if you are lucky (my E8400 needed 1.4+ volts to push past 3.7Ghz, while my Q9450 does it on less).
I am often surprised when I look down at the screen on my G15 keyboard and see all 4 cores doing significant work during gaming. If you are like me... you'll buy the cheap dual and then get the upgrade itch for a quad a couple months later. I would saved significant money if I just got the quad right away. I've seen the Q9550 for $239 at canadacomputers a week or two ago.
Rig: HAF922, Q9450, GA-EP45-UD3P, Corsair H50, 2x2GB Patriot Viper DDR2 800, HIS 5850
OC: 24/7 3.7Ghz @ 1.3v CPU-Z
Old July 6, 2009, 04:40 PM
Gellidius's Avatar
since my first pc i've always had single core cpu's and always had problems cause i couldn't refrain myself from multitasking.
since i got this q6600 quad, never had problems multitasking.
Buy a quad.
Jacques
Ego cogito, ergo deus non est.
Old July 6, 2009, 05:08 PM
Originally Posted by shayan288 View Post
And the e8400 can sometimes be had for like $110... but yeha I still vote for the q9550.
e8400 new? q9550 was $200 a couple weeks ago at ncix and direct canada.
Old July 6, 2009, 05:17 PM
shayan288's Avatar
No i meant, on a forum or on craigslist, and I thought 200 for a q9550 for a forum of craigslist aswell...
The 288
Q9550 E0 stepping @ 4Ghz
Gigabyte EP45 UD3P
G.Skill pc2 8500 1066mhz RAM
Western Digital 250gb
Antec 1200
XFX HD5970
Steelseries Xai Laser Mouse
Windows 7 Ultimate x64
Old July 6, 2009, 07:12 PM
CroSsFiRe2009's Avatar
I wouldn't touch a cpu off craigslist even if it was offered on a golden plate but that's just me
Old July 7, 2009, 09:13 PM
Realityshift's Avatar
+1...
Having owned an E8400 I can honestly say this is a BEAST of a CPU, and I have a hard time seeing it falling behind much over the next 2 years. That being said I am currently looking at picking up a Q9550 and selling off my E8400 possibly this week. 2nd video card or quad.... so hard to decide.
The Builders Hammer
Old July 7, 2009, 09:16 PM
shayan288's Avatar
I hated my e8400. I couldnt go past 3.6 no matter what and I was watercooling, but that is probably just cuz I had a 'bad chip'
The 288
Gigabyte EP45 UD3P
Antec 1200
XFX HD5970
Old July 7, 2009, 09:39 PM
Eagle Eye's Avatar
Correct me if I am wrong, but isn't 790i chipset not a great chip for qauds as far as overclocking is concerned?
EO stepping solved that, I hit 4.25GHz on mine.
EE
  #19 (permalink)
Old July 7, 2009, 09:41 PM
We still have not hit a point where quads are benefiting over a dual in most cases.
It comes down to user preference of what they use their computer for and the software used.
So much software isn't multithreaded yet and only a select few games are finally going there.
You'll honestly see little difference in stuff unless its specifically written to use multithreads.
Go for the 8400 and you'll be PLENTY happy.
  #20 (permalink)
Old July 7, 2009, 09:42 PM
Jake_HT's Avatar
Quad... 4 sho.
http://jakeht.deviantart.com/
Q9550 Temps Zeroman_IR CPU's and Motherboards 14 April 20, 2009 03:11 AM
[WTB] Q9450 or Q9550 HoTiCE_ Buy/Sell & Trade 1 March 7, 2009 07:39 AM
Intel Q9550 Like new renoracer Buy/Sell & Trade 10 December 7, 2008 08:46 AM
500w and q9550 mailaw Power Supplies 0 December 5, 2008 03:59 PM
LF: Intel E8400-E8600 or Q9450-Q9550 Dashock Buy/Sell & Trade 4 August 15, 2008 07:11 PM
