Originally Posted by Soultribunal I find comparing these two particular chips is really a moot point.
The i7 Is a better performing chip all around.
However putting a decent AMD system together will be cheaper.
Seeing as how a very good Gigabyte AM3 board can be had for around 125 or so.
It all depends on how much you want to spend.
ST |
Right now I have the AMD Phenom 9950 BE, 8GB PC6400 G.Skill RAM, and a BioStar TA790GX Mobo. Im selling these to a friend, for part of his build, cause he just wants a quick computer, etc. etc. etc. So with that money + $250 or so, Ill upgrade.
$750 - $850 budget
So ya, go from there.
Originally Posted by Ogdin You going to run sli/crossfire or just a single vid card? If your just using a single card the performance differences are basically nil,so i'd say go with the amd chip.But if you run multi gpus the i7 starts to flex its muscle,and the ability to run sli or crossfire on most x58 motherboards is a big plus for i7 in my books. |
Right now, Im using a single 4870x2, I was thinking of selling that off, and buying two 275's but I have no idea on that yet, and that probably wont happen.
