Old June 28, 2009, 05:55 PM
Default Multiple processors question
Sorry if this is extremely obvious but I'm a noob LOL. If I have a dual core processor at 2.2 Ghz does that mean each processor is 2.2 Ghz making it overall 4.4Ghz? And also in gaming is a dual core a lot better than a single?
Old June 28, 2009, 06:03 PM
b1lk1's Avatar
No, you don't add the speeds. Yo have a 2.2GHz CPU capable of running 2 threads at once.
single < dual < quad < whateverelseexistsaboveaquad
MY HEATWARE
Old June 28, 2009, 07:13 PM
Actually - to answer your question, YES, a dual core is just that, two processors - each core is running at 2.2Ghz - however, it does not necessarily mean you will get the equivalent of 4.4Ghz at all times - however an application that is optimized to use multi cores, like a rendering app that uses 2 cores at 100%, yeah I guess you can say you get nearly double the speed as a single 2.2Ghz - I've experienced it with a video rendering program myself, otherwise your tasks are balanced across the 2 cores. (example 50% usage on one core and 50% usage on the next).
Old June 28, 2009, 08:05 PM
Arinoth's Avatar
Exactly what DarkStar said, you benefit only if the application is designed to run on multiple cores. Say you had a quad core and an application was only optimized for 2, both CPUs (dual and quad)are using the same amount of cores to run the application. Meaning you could run identical systems with the only difference in the CPU (dual/quad) and unless the application is designed to benefit with the quad, it'll basically run as fast as the dual core
Old June 28, 2009, 08:42 PM
Oh ok I see thanks for the help.
Old June 29, 2009, 12:44 PM
Actually even if your apps/games do not fully use all cores or optimized for multicore, you can STILL get advantages over a single core - Since the tasks are balanced across cores, that leaves you some power for running simultanuous applications - Example you could be burning a DVD, watching a video and rendering something in the background, these will be balanced across cores and you will benefit over a single cores. If you are only running one app at a time, usually it will be balanced at 50% use one core 50% the other, result, no benefit over a single core.
is the 1000GHz Processors in the near future? Shadowmeph Press Releases & Tech News 12 April 6, 2009 11:00 PM
Paint Shop Pro on multiple machines, quick question Cowinacape O/S's, Drivers & General Software 0 October 29, 2008 02:48 PM
NCIX price drops on intel processors! belgolas CPU's and Motherboards 8 August 15, 2008 05:39 AM
Intel's Bloomfield motherboard LGA1366 for nehalem processors silverchair CPU's and Motherboards 1 April 5, 2008 07:52 AM
New Yorkfield Processors Out In Stores!! vertex112 CPU's and Motherboards 5 March 30, 2008 06:59 PM
