Old June 21, 2009, 10:39 AM
Unhappy 790FX vs 790GX?
so I'm a novice at AMD builds, and I want to build a AMD based gaming computer in the summer time based on the Phenom II platform....but I still don't quite know what the difference is between 790FX and 790GX.
here's what will probably be going in to this computer:
CPU:Phenom II x4 940 (is it really worth the extra 80 bucks to go for the 955?)
Mobo: Unknown?
GPU: 2x4890
RAM:Unknown?
HALP plz
Old June 21, 2009, 12:18 PM
CMetaphor's Avatar
Quadfather
If youre going for 2x 4890s in crossfire, then you should take a motherboard with a 790fX chipset. The 790gx pushes crossfire configurations down two 8x/8x rather than the 790fx's 16x/16x. For a manufacturer, id suggest Gigabyte.
Old June 22, 2009, 08:46 AM
I would go with the FX as well. For crossfire mode, it faster and overall it a faster board then the GX, it's also easier to overclock. Be careful if you buy a AM3 motherboard as it only works with AM3 CPU. The AMD Phenom II X4 940, is a AM+ CPU.
Have a look at the Gigabyte site for the CPU support list for a AM3 motherboard:
GIGABYTE - Support&Download - Motherboard - CPU Support List - GA-MA790FXT-UD5P (rev. 1.0)
Once you decide of the motherboard, have a look at the CPU support on the vendor site so you don't get a bad surprise.
Old July 5, 2009, 07:07 AM
i just wanted to quickly ask without having to make a new topic
i understand that if u plan to go crossfire, a FX mobo would be best, however what if I intend to use a single card (4870x2), should I still get a FX mobo or would a GX (some reason gigabyte only has 790X.. no G!) be sufficient?
Old July 5, 2009, 07:37 AM
Sagath's Avatar
Check the chipset on the gigabyte board to be sure.
As for the xfire question: The single card wont be hampered by either FX or GX, as the GX runs single cards in 16x mode. Its only when you 2-card that it drops to 8x8x.
Its been proven that the bandwith on the 48xx and 2xx cards is NOT bandwith limited even in 8x8x mode. I'll try to dig up the test I saw. I think it was on OC.
Old July 5, 2009, 03:43 PM
Silvgearx's Avatar
if your gonna go single card and want cheap.
go for the Newegg.ca - GIGABYTE GA-MA770-UD3 AM2+/AM2 AMD 770 ATX AMD Motherboard - AMD Motherboards
i been reading a lot of amd lately, most of there cpus don't extreme boards to get a decent overclock.
which cpu your gonna use?
but for best $ amd board i would go for a asus 790gx or gigabyte 790x, both of these are in the $120 CAD range but thats just my though since i have a set of DDR2 sitting here
Old July 5, 2009, 05:22 PM
im looking to get a AM3 socket tho, most likely phenon II 955. I know that processor can fit into am2+ mobo but I want a am3 mobo for futureness-ness :)
Old July 6, 2009, 07:06 PM
Would the 790GX mobo be ok for the single gpu 4870x2? Or do I have to go for a FX board to reap the max benefits?
MSI 790GX-G65 ATX Motherboard Chris CPU's and Motherboards 4 April 18, 2009 05:26 AM
790Gx - HTT 3.1 and 45nm Phenoms. CMetaphor CPU's and Motherboards 2 August 21, 2008 09:17 AM
Amd 790gx/sb750... CntdwnToExtn CPU's and Motherboards 5 August 9, 2008 05:09 AM
DFI LP Dk 790FX-M2RS problem s_8ball CPU's and Motherboards 7 April 9, 2008 09:45 PM
790FX motherboards revealed! Zertz Rumor Mill 7 November 9, 2007 05:19 PM
