Old July 14, 2007, 02:22 PM
sswilson's Avatar
Default Comment thread for Gigabyte P35-DQ6 review
Comments, questions, and critiques welcome.
This board/cpu/mem combo will be up and running under WC for a week. I'm more than willing to check out some different settings for the curious.
The review can be found here...... http://www.hardwarecanucks.com/hardw...rd-review.html
Old July 14, 2007, 04:02 PM
lowfat's Avatar
$316!?!?! Wow I would never pay that much for this motherboard, I am glad mine only cost me half that.
Although I do love my P35-DQ6, it would not be worth that price.
1. Xeon ES 4c/8t * X79-UD3 * HD7970 * 16GB DDR3 * 64GB Crucial M4 * 80GB ioXtreme * 1000W Silverstone
2: 27" iMac * i5 750 * 80GB X25-M G2 * 4GB DDR3 *
3: 2600k * P8P67 Pro * GTX460 * 16GB DDR3 * 40GB X25-V * RR2314 * (2) Sans Digital TR8M-B * 46TB * 1050W Enermax
Old July 14, 2007, 04:04 PM
3.0charlie's Avatar
Question
You're using 2 X 1Gig Supertalent PC6400 T800UX2GC4 which is 800MHz ram, and you specified that "Stable memory OC was 1062 5-5-5-15 5:6 divider..." Looking at the s/s below, the closest multiplier to a 5:6 divider is 2:1. How did you achieve the 5:6 divider, using that BIOS?
This is directly related to my question "dram ratio". There is something I don't get, or a BIOS setup I don't understand.
Thanks!
John
Old July 14, 2007, 04:30 PM
sswilson's Avatar
Sorry, I guess I've got my terminology wrong..... I suppose I should have said ratio rather than divider.
The 5:6 figure I was using is what CPU-Z reports the memory as running at.
The memory is running at the selection shown in the picture which is 2.40.
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
Old July 14, 2007, 04:34 PM
sswilson's Avatar
Heh.... where did you find a DQ6 for $150?????
It is pricey, but the price is in line with other new chipsets when they were first released.... I remember seeing the 680i chipset boards being offered for +$300 when they first came out.
Old July 14, 2007, 05:31 PM
lowfat's Avatar
I bought mine from Canada Computers back in the beginning of May for $166 :)
A P5K-Deluxe is only $260. If I had to pay $300+ for my board I would of definitely went with a P5K-D for $50+ less.
Old July 14, 2007, 05:38 PM
sswilson's Avatar
So, aside from price, how's your experience with the board been?
I mentioned it in the review, but I'm still amazed at how easy it is to OC on this board.
Old July 14, 2007, 06:05 PM
lowfat's Avatar
It is a pretty good board, but I get really annoyed with it on occasion. I run 3.6GHz, 400MHz FSB with a 4:5 divider, is well over 24H prime stable, yet often I'll change from a different OC to this one and i will get continuous restarts. And the only way to get it to boot is remove 3 of the 4 sticks of ram.
But besides that the board is great, i am almost dissapointed it is so easy to overclock
Old July 14, 2007, 06:12 PM
lowfat's Avatar
I really don't think you are in the wrong. I have never heard of anyone calling it a DRAM multiplier among overclockers.
Old July 14, 2007, 06:18 PM
sswilson's Avatar
Strangely enough, that's the way I felt about it as well...... :)
Weird one on the "stable" OC which won't originally boot.... It almost sounds like a setting which isn't available to tweak being reset when you drop down to one stick and then bumping up as you put them back in.
Comment Thread for Gigabyte 3D Aurora Case Review SKYMTL Cases 33 January 7, 2011 08:54 PM
Thermalright HR-03 GT Review Comment Thread SKYMTL Water Cooling 9 April 10, 2008 02:52 PM
Comment Thread for BFG 800W PSU Review SKYMTL Power Supplies 24 January 3, 2008 12:31 PM
Comment Thread For OCZ ATV Turbo review SKYMTL Storage 20 October 17, 2007 05:36 PM
Comment Thread for Gigabyte Odin GT 550W Review SKYMTL Power Supplies 4 July 16, 2007 09:24 AM
