Old June 13, 2009, 09:52 AM
jcmaz's Avatar
Default Idle Temp Check
Hi,
I'm using the stock AMD headsink on my computer and at idle, i'm at 55-60 degrees. I think its like around 20 degrees at home. Is it normal?
-Plato
Old June 13, 2009, 10:32 AM
howpet's Avatar
YIKES!!
Neverhad anything to do with AMD but that is hot!
Is that bios telling you this or software?
If bios better check voltages or probably heatsink....soon
Old June 13, 2009, 10:49 AM
jcmaz's Avatar
Its Core Temp that told me. But it coincides w/ EVGA Precision Tool.
-Plato
Old June 13, 2009, 11:19 AM
Neolithium_Wpg's Avatar
Might want to grab some thermal paste and reseat your heatsink.
MacBook Air 13" (2011) | Blackberry Bold 9900
A Veteran, whether Regular Force, Reserve or Retired- is someone who, at one point in their life, wrote a blank cheque made payable to the Dominion of Canada for an amount of "Up to and including my life"
-Author Unknown
TRUE 120 idle and load temp for i7 920 hatabilly0204 Air Cooling 10 May 26, 2009 06:04 PM
QX6850 idle temp? pp1111 Troubleshooting 3 April 23, 2009 09:16 AM
what is normal idle temp for e8400 Shadowmeph Air Cooling 15 December 29, 2008 10:46 PM
just dropped my idle temp by... rob123 Video Cards 11 July 23, 2008 09:03 PM
CPU temp or Core temp? E6420 NOOB Delavan CPU's and Motherboards 18 May 28, 2007 05:07 AM
