Old June 12, 2009, 08:14 AM
Cranky's Avatar
If your willing to spend more cash, try this Combo. It will beat the pants off all of the other hardware listed here. The motherboard is a good overclocking board, and you should be able to get the 920 up to 3300mhz.
Asus P5K Deluxe / Intel Core2Quad Q9550@8x425@3400mhz(1.225v) / Arctic Cooling Freezer 7 Pro / 4Gigs DDR2 1066mhz(5-5-5-15) Corsair Dominator / Diamond HD4870x2 / Asus Xonar / WD Raptor 74gb / Hitachi 160GB / Antec Quattro 850w / Logitech Z-680 5.1 / Dell Ultrasharp 24" / 2 LG Optical Drives / Vista Ultimate 32bit / A tower that's been drilled, cut, and bent to fit all of my fans
Old June 12, 2009, 08:18 AM
Sagath's Avatar
If you're into overclocking like you mentioned I think wilsons' idea of a P2 720 is the right way to go. Spend 300, and with the extra 150 you -want- to spend, try dropping it into a basic CPU watercooling setup. Then overclock the 720 like mad! Ride the luck wave and hope for an unlockable batch of 720 too. Wouldnt that be a nice lottery win?
Not only will this set you up nicely for overclocking, but you'll have the WC setup for years to come out of the small investment too.
Food for thought!
4890 , advice , cpu , motherboard
Seeking advice - 775 Mobo, hdd's, ram mattydies CPU's and Motherboards 5 January 30, 2009 09:12 PM
Need some advice on new MOBO for DDR3 that I won on this site bushwickbill New Builds 0 August 28, 2008 09:51 PM
Need advice on mobo? bushwickbill CPU's and Motherboards 3 August 5, 2008 03:29 PM
Mobo advice for new build D1rtyB1rd CPU's and Motherboards 26 March 6, 2008 02:23 PM
Advice on mobo needed badly 999Virus999 CPU's and Motherboards 8 January 11, 2008 11:23 PM
