Old July 12, 2007, 02:25 PM
Eldonko's Avatar
Hardware Canucks Reviewer
For building it's basically the same thing, ocing is a little different with bootstraps and such but you get the hang of it quick. Again, Im not trying to pursuade you from buying AMD, I just want to highlight that there are options w/ Intel that could be better. If you wait 2 weeks the Intel price drops will allow a killer system for cheap.
Old July 12, 2007, 02:30 PM
Originally Posted by Eldonko View Post
F Again, Im not trying to pursuade you from buying AMD, I just want to highlight that there are options w/ Intel that could be better.
sure...I'll keep in mind that AMD isn't the only solution....
Too bad, I was considering buying some AMD shares...LOL
Gigabyte P35 DS4 (rev 1.2)
Intel Q6600 cooled by ultra120 extreme+Scythe 1600rpm
2GB Crucial DDR2 1066
XFX 8800 GTS 320MB
Seagate Barracuda 160GB + WD 250GB
NEC DVD writer
Corsair HX620W
Old July 12, 2007, 03:54 PM
Eldonko's Avatar
Hehe, you might want to wait some time on that.. ;) I bought a bunch of Intel when C2D was about to come out @ $17, now they $26 whereas AMD has dropped to $15.
Old July 12, 2007, 04:13 PM
XFX 8800 GTS 320MB
NEC DVD writer
Corsair HX620W
Old July 12, 2007, 06:00 PM
i went from an amd x2 3800 at 2.8ghz on the same mobo as you to the system in my sig. HUGE difference. especially in cpu limited games like cs source (mostly what i play).
ASUS P6T
Intel i7 920 @ 3.8GHz w/ 1.35v
3 x 2048MB PC3 12800 OCZ Platinum XTC @ 1528MHz (7-7-7-20) w/ 1.6v
2 x Sapphire HD 4870 1GB
SoundBlaster X-Fi Platinum
2 x WD1500ADFD RAID 0
4 x WD5000AAKS RAID 0+1
Tt Armor Aluminum Tower
Enermax Galaxy 1000W DXX
DELL 2405FPW, 1905FPW
Old July 12, 2007, 06:59 PM
4GB, E6600, 4 HDDs, 8800GT, 1000W...nice rig !! expensive too LOL
XFX 8800 GTS 320MB
NEC DVD writer
Corsair HX620W
Old July 12, 2007, 09:24 PM
6 hdds actually. :P thx.
when i had the 3800 i had 2gb and the raptors, with a x1950xtx.
i actually don't have the dvd drive in right now cause this motherboard only has 6 internal sata ports. i'm looking for an external esata enclosure for 5.25" drives but have yet to find one...
ASUS P6T
Old July 12, 2007, 10:00 PM
Misoprostol
Guest
Posts: n/a
It's basically the same thing to set up an Intel system. Let us know when you get the parts, and we'll help you get things set up if you run into any problems.
  #19 (permalink)
Old July 12, 2007, 10:58 PM
Patriote's Avatar
Yeah. For once im not the only 1 to think that buying AMD ATM is wrong. And it'll be even bad when price drops in 2 weeks!
- Asus P8Z68-V PRO
- Intel I5 2500k @ 4.5Ghz
- Asus Geforce 580GTX DirectCUII Fermi
- 16GB Corsair Vengeance Low Profile
- Ultra X3 1000 Watt
- Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
- Corsair Vengeance 1300 Gaming Headset
- Crucial M4 SSD 128GB \ WD Caviar Black 1TB
- CoolerMaster 690II Advanced
- Dell UltraSharp 24''
- Noctua NH-D14
  #20 (permalink)
Old August 1, 2007, 11:12 AM
Il Duce's Avatar
it actually already dropped since july. The 6000X2 was 279 and is now 200! (according to canada comp's web)
How much power would you recommend? Cptn Vortex Power Supplies 7 December 10, 2007 03:35 PM
Please Recommend a Case for my Needs SKYMTL Cases 21 August 29, 2007 09:41 AM
Recommend me a good 5.1 Surround sounds Speaker set! Patriote Audio 23 July 28, 2007 03:57 PM
Recommend a DX10 Game Babrbarossa Gaming 16 July 2, 2007 07:10 PM
