Old June 8, 2009, 09:07 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
I believe the type of program you are looking for is called an Affinity Mask Tool.
As far as I know however, processor affinity is designed to be dynamic from one program to the next and messing with that can cause issues with certain applications.
Old June 8, 2009, 09:40 AM
El_Fiendo's Avatar
It's a trade off, what I'd do with his system is assign cores 0-13 and leave the last 2 cores as open for any program or task that cropped up unexpectedly. This way he's optimized 14 cores and there are 2 leftover to run cleanup of miscellaneous. Oh and, CMetaphor your solution and mine are strikingly similar, only yours is via program and mine is editing shortcut / run command lines.
Old June 8, 2009, 09:55 PM
Any update CM?
Old June 9, 2009, 05:21 AM
CMetaphor's Avatar
Quadfather
Originally Posted by Rommel View Post
Any update CM?
Didn't have time to last night. Was busy trying to "blend" something (different thread, lol). But I'll try when I get a chance, unfortunately I'm going to be fairly busy during the evenings for the rest of this week so It may have to wait a bit, hehe. I'll let you know
Old June 9, 2009, 07:09 AM
lcdguy's Avatar
not sure if you can use this for your useage but i use this to force older applications to only run on 1 core.
Robpol86.com - ImageCFG.exe
Old July 21, 2010, 09:07 AM
Shadowmeph's Avatar
Sorry for the Necro of this but does this actually work ?
Old July 21, 2010, 09:48 AM
stoanee's Avatar
Process Lasso, the Windows process optimizer!
Try this?
heatware
Old July 21, 2010, 10:05 AM
sswilson's Avatar
Process lasso worked fine for me as well. The initial issue however was due to more than the traditional 8 cores on multi-cpu motherboards, and apparently the freely available affinity programs don't support more than 8 physical cores.
Not sure if the question was related to a multi-cpu setup or not..........
  #19 (permalink)
Shadowmeph's Avatar
Originally Posted by stoanee View Post
I totally forgot about this Program now I just need to remember how to use it lol
  #20 (permalink)
Old July 21, 2010, 11:11 AM
Bill2's Process Manager supports up to 32 threads.
CLI+GPU Affinity Setter geokilla HardwareCanucks F@H Team 0 September 12, 2008 08:10 PM
100$ Processor... Copper94 CPU's and Motherboards 18 August 7, 2008 05:31 PM
Intel Affinity Patch? J2TheROC CPU's and Motherboards 4 May 23, 2008 07:15 PM
Advice on processor Cpt Martha CPU's and Motherboards 8 May 20, 2008 10:05 AM
Setting Core Affinity Cptn Vortex HardwareCanucks F@H Team 6 January 7, 2008 10:42 PM
