Old June 4, 2009, 07:33 AM
jcmaz's Avatar
Default More FPS by changing Processor
If i change my processor from the amd 5200+ 2.7 ghz to a 720 BE (or any other 95W PII), how much of a difference in FPS will it get?
the games that i play are
GRID
HAWX
TF2/Insurgency
Far Cry 2
and many newer games
System specs are below
THX
-Plato
Old June 4, 2009, 07:43 AM
"Quote This..."
You'll gain some, but not much i'm afraid. The extra core will help in grid and FC2 but you're only jumping 100mhz in clock, a better chip though.
Old June 4, 2009, 07:50 AM
Eagle Eye's Avatar
I wouldn't expect a dramatic increase in FPS I think alot of it depends on whether a game is more cpu dependent or gpu dependent (most likely). That being said any upgrade based on your specs you're likely to see improvements in all areas. In my experience upgrading my GPU was more beneficial than upgrading my CPU despite it being heavily bottlenecked.
Its also important to remember that a lot of performance most of us get out our systems is because we are all pretty highly overclocked.
Regards,
EE
Old June 4, 2009, 08:57 AM
If u'r going to a x3 720BE (overclocking is easy 3.5ghz) even though high end fps may not jump dramatically minimum end fps may increase and u'd be ready for an eventual gpu upgrade down the line, the x2 5200 won't do much good over a gts250 card. The 9600gt is the biggest drag on the game side.
Gaming FX 8350 stock / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use x4 965BE 3.6GHZ/GA 970 Gaming/ R7 265 1GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
Old June 4, 2009, 11:21 AM
kiwik's Avatar
That M2A-VM will not support Phenom II CPUs.
ASUSTeK Computer Inc.-Support-
Old June 11, 2009, 09:47 PM
aviduser's Avatar
personally I'd change out the vid card before the cpu, unless your gaming at fairly low resolutions.
I5 4670K 4.4ghz - Gtx 780 Amp - 2x4 Corsair Vengeance - MSI z87-g43 - Tx 850w - Asus pbq278q
CL changing to 4.0? somecanadianguy RAM 4 April 20, 2009 04:18 PM
changing cooling gingerbee Water Cooling 2 April 17, 2009 09:45 PM
Multyplyer keeps changing..... WTF frosty Overclocking, Tweaking and Benchmarking 16 January 31, 2009 08:26 AM
The Times they are a changing. KnSKranky New Builds 0 September 3, 2008 05:29 AM
changing psu? djnocide Power Supplies 4 December 12, 2007 07:07 PM
