Old June 3, 2009, 04:57 PM
Pokeguylow's Avatar
Default 40C mobo normal?
Hi, my mobo is running at 41C-46C, is that normal? its a Gigabyte GA-MA790X-UD4P.
Old June 3, 2009, 05:07 PM
Pokeguylow's Avatar
i wonder where the sensor is and how can i improve the temperature.
Old June 3, 2009, 05:24 PM
3.0charlie's Avatar
Usually around the NB. Running at 40C is not a problem, and far from becoming one. My rigs when running at 100% reach a board temp of 50C+. No issues.
Hydro-Quebec is salivating...
Old June 3, 2009, 05:37 PM
gingerbee's Avatar
my x48 nb is at 41c right now 100% load 46c
Old June 3, 2009, 06:54 PM
thenewguy001's Avatar
my gigabyte idles at 38C and runs up to 46C on 100% load
i5 2500K @ 4.0 GHz
2 x 4GB G.Skill Ripjaws X
Patriot Pyro 240GB
Gigabyte HD 6970 OC
Gigabyte Z68X-UDH3-B3
Seasonic 760W
Coolermaster Hyper 212+
CM690 w/ 1-80mm, 6-120mm fans.
Old June 3, 2009, 07:28 PM
Gellidius's Avatar
My Asus NB is at 47C right now, with the cpu's 4 cores (OC'ed to 3.6GHz) running at 100% 24/7;
MoBo at 27C;
room temp at 22C and i go to sleep at night without nightmares. ;-)
Jacques
Ego cogito, ergo deus non est.
Old June 4, 2009, 01:04 AM
NB at 46, SB at 51 water cooled....but nvidia chipset. The board itself reads 36C, sounds plenty good to me!
Is this Normal? Soultribunal HardwareCanucks F@H Team 12 May 27, 2009 04:43 AM
what is normal idle temp for e8400 Shadowmeph Air Cooling 15 December 29, 2008 11:46 PM
will canada go back to normal? CTA Off Topic 9 October 25, 2008 12:22 PM
FS-s939 X2-3800, OCZ ram, Ac Freezer 64 Pro, ASRock mobo, DFI mobo, Asus mobo..more stoanee Buy/Sell & Trade 14 June 7, 2008 06:24 PM
CS:S ti normal program Long John Silver Gaming 5 June 21, 2007 07:32 PM
