<~----> My build, suggestions? - Hardware Canucks
Old July 9, 2007, 12:22 AM
Default My build, suggestions?
I'm planning on upgrading my computer w/ $600~
Here are the items I have so far, what I need is suggestions on which parts I should get that are better and around the same price! It's going to be overclocked as much as I can btw.
Asus P5K motherboard
I need a board that is cheap and can overclock real well. I saw the DFI Dark as another selection, but I heard this chipset overclocks better.
Intel Core 2 Duo E4300
I was tied between this, the E4400, and the E6320.
Mushkin EM PC2-6400 2GB
I need 2gb of decent ram in a cheap range, I didn't see a reason to go really higher, but if there is anothing better within this price range I'd like to know.
ASUS Radeon X1950 Pro
And finally my video card! I don't have the money to go all out on an 8800GTS, so in the time being I think this should suffice. It's at a great price and has a very nice cooler on it.
As I said suggestions/alternatives would be great! Thanks!
(All products on Direct Canada or NCIX please)
Old July 9, 2007, 04:26 AM
i wouldn't change a thing. with the e4300 you don't even really need a good ocing board. any of the new p5k boards will do 333fsb so 3ghz for you is a reasonable/solid goal.
ASUS P6T
Intel i7 920 @ 3.8GHz w/ 1.35v
3 x 2048MB PC3 12800 OCZ Platinum XTC @ 1528MHz (7-7-7-20) w/ 1.6v
2 x Sapphire HD 4870 1GB
SoundBlaster X-Fi Platinum
2 x WD1500ADFD RAID 0
4 x WD5000AAKS RAID 0+1
Tt Armor Aluminum Tower
Enermax Galaxy 1000W DXX
DELL 2405FPW, 1905FPW
Old July 15, 2007, 12:31 AM
r0k0's Avatar
to save you even more.. if you want.. buy the e2*** series.. they have 1mb l2 cache but you dont need more than 1mb.. :P unless you copy and paste loads.. and they overclock nicely to 3ghz easy at lower price... call those e2*** chips the Celeron version but in much better performance and and price than the normal celly's we had before ;)
thats just if you wanna save money otherwise buy what you had in mind and if you want the 8800GTS :P
Main Rig
Intel Core i5 2500K - 5.0
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
AMD Radeon HD 6990 4GB 880 / 1300
Crosair 600T White / Enermax Revolution 920W
A-DATA 120GB SATA3 SSD / Seagates 1TB Spare SATA3
Canadian Eh ?
Old July 16, 2007, 10:39 AM
with the p5k you can run the ram at 1066, it costs a bit more to get ram that will run at that speed without overclocking it but it will be worth the price increase for the performance increase.
Old July 16, 2007, 01:03 PM
Eldonko's Avatar
Hardware Canucks Reviewer
I would go 6320 over 4300, 4mb cache and prob better max fsb.
Old July 16, 2007, 08:59 PM
r0k0's Avatar
4mb cache is only uselful if you copy and paste stuff and etc... other than that 1mb is perfect.. and on Guru 3D .com a guy with a E2x xx O/Ced one to 3.9ghz...
Main Rig
Canadian Eh ?
Old July 16, 2007, 09:09 PM
JD JD is offline
I think the cache is more than just for copying and pasting...
I'd rather a E6320 with 4MB cache over the E4300. Also since your intending to overclock, get some decent cooling for the CPU. Also make sure your case has some airflow as well.
Old July 16, 2007, 10:52 PM
slugbug's Avatar
I suggest you wait for the Intel price drops next week
New build suggestions. taal CPU's and Motherboards 1 February 4, 2008 10:58 PM
Suggestions on WC build sswilson Water Cooling 18 September 19, 2007 03:05 PM
First build - looking for suggestions (am noob) Nimbus CPU's and Motherboards 17 July 17, 2007 01:35 PM
first build, suggestions help? mgp141 CPU's and Motherboards 5 March 30, 2007 03:24 PM
Suggestions On New Build BALISTX CPU's and Motherboards 14 February 14, 2007 12:10 AM
