Old May 31, 2009, 05:51 AM
Default Q9550 to stock cool or custom cool?
Hey guys, I recently purchased a Q9550 and i was just wondering what you would reccomend in terms of cooling. Im not planning on overclocking it (especially after i payed $300 for it) but i've been hearing that the stock cooler provides inadequate cooling even without overclocking :(
Any help would be appreciated :D
Old May 31, 2009, 06:03 AM
gingerbee's Avatar
get a xigmatek cheap and they work great. P.S point of overclocking a 300 cpu so it work like 1200 dollar cpu or faster just a little poke at the none overclockers ha ha
great cpu even at stock settings
Old May 31, 2009, 06:38 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Xigmatek 1283 or OCZ Vendetta 2. Splurge and get the "crossbow" i7 backplate for it (both are same w/ slight difs in fin array). :)
Old May 31, 2009, 06:17 PM
Delavan's Avatar
If you grab the Xigmatek Dark Knight, it comes with the crossbow backplate already, and can be pricematched to $50. IMHO, good deal.
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
Old May 31, 2009, 08:12 PM
Eagle Eye's Avatar
What!!
Thats the exact reason why you spent $300 so you can overclock it. With a good board you should be able to put that chip up to at least 3.2GHz on stock voltage, besides do you really want that cpu to be holding that GPU of yours back. Assuming you have a decent card already.
Regards,
EE
Old May 31, 2009, 09:03 PM
Silvgearx's Avatar
how are your temps? if its under 70C for load i won't worry much about it.
but yea those intel stock HSF are loud and hard to work with, even those look like simple freakin small pins. the chances of a loosen pin is high if you don't know how they work
Old June 1, 2009, 12:41 AM
Umm im actually planning to purchase the rest of my comp (ie. video card and ram) later this year. I only got the cpu now to utilise a discount thing thats running. Thanks for the help though guys, ill take your suggested coolers into consideration. And yes, if the temps allow for it i shall overclock :) (hehe but your gonna have to help me with that when it comes to it also, cause im really quite noob :D)
Old June 1, 2009, 06:15 AM
Eagle Eye's Avatar
What kind of motherboard are you working with?
EE
Old June 1, 2009, 09:44 PM
wait, I don't get it.
if you already got the chip and stock cooler, then why not just install it and see the temps for yourself?
and if you dont like it, then buy a better cooler like the ones mentioned above.
EDIT: oh wait, I just saw your other post and assume that you still haven't bought an MoBo yet, so then wait till you get all your stuff and test it out.
Old June 2, 2009, 05:42 AM
dhoshaw's Avatar
My DK should be in tomorrow. The backplate is why I got the DK instead of a regular S1283; hate those push pins. Once I have it installed, I should be able to push to 3.8+ GHz.
Intel Q9550 @3.8 GHz
Sapphire 5850 Toxic
XFX 9800GX2
Gigabyte GA-EP45-UD3P
2 x 2 GB Corsair XMS2 1066C5
2 x WD 640 GB Raid 0 + WD 1 TB
Haf 922 / Antec Signature 850
Windows 7 Ultimate x64
This is sooo cool encorp Off Topic 9 December 3, 2009 06:07 PM
Cool video of TFC White Mosta custom pait job Dazmode Water Cooling 1 April 14, 2009 10:23 AM
Wanna see something cool? WolfBane Off Topic 16 February 26, 2009 05:40 PM
Now thats Cool... DK2 Cases 9 June 10, 2008 10:47 PM
Cool Screenshots Supergrover Gaming 12 March 10, 2007 03:16 PM
