Old May 23, 2009, 02:08 PM
CORE's Avatar
Default Motherboard and thermal paste question
Hi. I was applying a new thermal paste to my cpu then suddenly my ocz freeze spilled onto some resistors due to my instinct of cleaning it up, it spread along the motherboard resistors. Now im worried if my motherboard will short if this happens. Will this affect my motherboard, if i spilled a considerable amt of thermal paste(ocz freeze) into the resistors of my motherboard. thanks
Old May 23, 2009, 02:11 PM
"Quote This..."
Nope. Not even arctic silver is conductive. I tested it with a multimeter.
Old May 23, 2009, 02:15 PM
CORE's Avatar
so eventhough a small portion of thermal paste spilled into the resistors of the motherboard it wont affect it in anyway?
Old May 23, 2009, 02:18 PM
Infiniti's Avatar
Pros
  • Excellent thermal conductivity
  • Not electrically conductive
  • Reasonably priced
  • Doesn't degrade over time
  • Performs on par with the competition
Cons
  • Nope.
Old May 23, 2009, 02:21 PM
"Quote This..."
this is the same question you asked last time :) The answer is stil nope.
Old May 23, 2009, 02:28 PM
CORE's Avatar
Just making sure. you guys a re the best. thanks v much !
Old May 23, 2009, 02:45 PM
geokilla's Avatar
If you're scared, just clean it up then let the motherboard sit there for an hour or 2 so whatever you use to clean it up can dry.
Old May 23, 2009, 03:07 PM
sswilson's Avatar
If you really want to get rid of it, get yourself an aerosol electronics/contact cleaner and spray the crap out of it.
Old May 23, 2009, 03:12 PM
Infiniti's Avatar
Yeah, I remember that advice from my thread.
*thinks back to when I got TIM in the CPU socket*
Thermal paste comparison Technokat Overclocking, Tweaking and Benchmarking 3 April 7, 2009 08:12 PM
Thermal paste for a phenom II Jonwall CPU's and Motherboards 9 February 6, 2009 05:34 PM
Thermal Paste application Mr. Gruntsworthy Air Cooling 9 October 11, 2008 07:18 AM
Thermal Paste??? Salavat23 Water Cooling 6 December 27, 2007 06:43 PM
Does core2duo come w/ thermal paste Magice CPU's and Motherboards 4 July 12, 2007 03:40 PM
