Old May 20, 2009, 08:08 PM
Default Best 955 mobo?
I'm looking for a good motherboard for my phenom 955 gaming rig
price is not an issue...
thanks for the help
Old May 20, 2009, 08:17 PM
Does this gaming rig require one videocard or two?
ADD-on soundcard?
SLi/Crossfire?
Old May 20, 2009, 08:31 PM
Soultribunal's Avatar
Good questions Cav,
Bang for the Buck, Gigabyte really shines.
Infonec Computers - Computer parts Canada, PC Components, laptop computers, motherboards, processors, CPUs and much more : GIGABYTE GA-MA790XT-UD4P AM3 4DDR3 2PCI/3PCI-E X1/2PCI-EX16
Regards,
ST
www.realhardwarereviews.com
Old May 20, 2009, 08:36 PM
cadav its:
2 4890's
no add on sound
crossfire
Old May 20, 2009, 08:57 PM
Well, the aforementioned UD5P is high on my list, and the MSI GD70 looks very promising as well, but I've yet to see it(the MSI) hit retail here in Canada. The MSI looks good in what I've seen floating around, and generally MSI is a fair bit more affordable than other OEMs.
Next up we can ask, DDR2/DDR3...becuase that also influences the choice, but quite obviously, DDR2 isn't something that still registers with me...it's old tech now, given that you can now get 4GB(even 6GB!!) of DDR3 for $100 or less, but of course, what you buy is ultimately up to you.
Old May 20, 2009, 09:25 PM
I was also wondering how to mount these ssd's into an antec 1200 : Newegg.ca - Patriot Warp PE32GS25SSDR 2.5" 32GB SATA II Internal Solid state disk (SSD) - Solid State Disks
and btw I will be using ddr3 (4gb patriot extreme)
Old May 20, 2009, 09:32 PM
You'll need mounts for the SSd's, as tehy are 2.5 inch. Your choice whether you want to convert to 3.5-inch(dunno how many 3.5-inch device the 1200 supports), or to 5.25-inch(there are a few that allow 4x 2.5 device into 2x 5.25 slots or less).
Old May 25, 2009, 12:32 PM
Cowboy's Avatar
If you were going with ddr2 I would have said to go with the DFI offerings...
They will be coming out with an AM3 version, the only question is when... I, for one, would wait.
Old May 25, 2009, 01:18 PM
You could go with the asus m4a79-t. I personally have the m3a version which is essentially the exact same board with an am2+ socket and ddr2 slots vs an am3 socket and ddr3 slots. Its probably one of the best boards out there for an am2+ based system, so i dont see any reason the m4a would be any different.
Case: HAF 932
CPU: AMD Phenom II 940 3.5ghz w/ OCZ Vendetta 2 Cooler
PSU: OCZ StealthXstream 600w
Mobo: ASUS M3A79-T Deluxe
Memory: 4gb OCZ Platinum 1000mhz ddr2
Graphics: 2x Sapphire 4830s in Crossfire
Keyboard: Logitech G11
Mouse: Logitech G9
HD:WD 640gb Caviar Black + 750gb Seagate
#hardwarecanucks on irc.enterthegame.com
Old June 20, 2009, 06:43 PM
niallm1dotcom's Avatar
Have a GIGABYTE-GA-MA790FXT-UD5P Motherboard and an Asus M4A79T Deluxe. From my research I think the MSI 790FX-GD70 (which M.B is better::Asus m4a-79-t Deluxe OR MSI 790FX-GD70) is probably best!
Hope you check my site: http://www.niallm1.com. Not fully up an running yet though...Stay tuned...
Tags
amd phenom 955 am3 mobo , amd phenom ii am3
AMD Phenom II X4 955 BE. Good contender to i7? bojangles CPU's and Motherboards 40 June 28, 2009 01:16 PM
955 or 940? upcoast604 CPU's and Motherboards 10 May 7, 2009 03:22 PM
NCIX has the Phenom II 945 and 955 up snoosebum CPU's and Motherboards 5 April 22, 2009 11:16 AM
FS-s939 X2-3800, OCZ ram, Ac Freezer 64 Pro, ASRock mobo, DFI mobo, Asus mobo..more stoanee Buy/Sell & Trade 14 June 7, 2008 06:24 PM
