Old July 2, 2007, 01:06 PM
Il Duce's Avatar
Lightbulb New build -Yes it's fun...
Purpose:Play current games (at least 60fps avg), alt-tab easily out of current titles/software/bt to msn, and of course running future OSes smoothly.
AMD X2 Build
AMD Athlon 64 X2 6000 279.99
Asus M2A-MVP Socket AM2 AMD 480X CrossFire Chipset + ATI SB600 Dual Channel DDR2 800/667/533 1394a Firewire 104.99
Corsair XMS2 TWIN2X2048-6400 2GB Kit (2x1GB) PC6400 139.99
Sapphire ATI Radeon X1950 XT 219.99
Antec SmartPower 2.0 500 Watt 81.95
826.91 subt
950.9465 wtx
(Prices quotes from Canadacomputers on July 2,07')
Infonec does sell some parts cheaper like the AMD6000 sells for 264 (259 w/ cash/debit) and other parts maybe 6-9 dollars cheaper than Canadacomp. But I'm lazy to drive all the way there...
I know 8600 blah blah blah. I'm just ATI in heart.
Old July 2, 2007, 02:01 PM
JayDee
Guest
Posts: n/a
Congratulations Il Duce :)
A new build is always fun! (what's wrong with us geeks :p)
Did you get a cooler for the 6000 to OC or are you going to play stock?
Good gaming to ya!
Old July 2, 2007, 06:24 PM
CMetaphor's Avatar
Quadfather
Caaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaase?
Old July 2, 2007, 11:21 PM
Il Duce's Avatar
I'm just using my old case if things don't fit i'm using my powertools to adjust that. Also don't need cooling since I don't oc.
Old July 3, 2007, 06:28 AM
You don't care for upcoming DX10 titles I take it? Judging by the X1950xt...
Q6600@3.2ghz
Asus P5N32-E Sli
4gb OCZ Platinum DDR2 @1100mhz
Antec P180
BFG GTX 260 Core 216
Corsair HX-620
Thermaltake Power Express 250W
Raptor150, WD 500gb. WD 300GB
X-Fi Extreme Music
Old July 3, 2007, 07:28 AM
belgolas's Avatar
up coming DX10 games will play in DX9 and won't look that different and will run a lot faster than in DX10 mode. read tomshardware on DX10 versus DX9. Even Crysis isn't that big of a difference from DX9 to DX10. So I guess he can wait till the next gen DX10 cards come out. The current ones I am a little disappointed in them.
Old July 3, 2007, 07:46 AM
I agree, the batch of dx10 titles out right now do not look a whole lot different then their dx9 brethren, but that would mostly be due to them not being native dx10 games... a patch isn't going to add a whole lot.
Why buy old technology though? An 8800GTS 320 can be had for about $300, and it will run DX9 titles a lot faster then a x1900 series card.
Q6600@3.2ghz
Asus P5N32-E Sli
Antec P180
Corsair HX-620
X-Fi Extreme Music
Old July 3, 2007, 11:27 AM
lol, that's nearly $50 for being lazy...
what monitor are you using? that goes a long way to determining what video card would best suit your needs.
also, why amd? overclocking an intel is so easy right now with all these p35 boards natively supporting 333fsb. an e6600 can be bumped to 333fsb from 266 with no vcore increase and no strain on any other component. at 3ghz it wouldn't even compare to your measly 6000+. not to mention current intel boards will fully support future intel cpus and current am2 boards will not fully support future amd cpus.
ASUS P6T
Intel i7 920 @ 3.8GHz w/ 1.35v
3 x 2048MB PC3 12800 OCZ Platinum XTC @ 1528MHz (7-7-7-20) w/ 1.6v
2 x Sapphire HD 4870 1GB
SoundBlaster X-Fi Platinum
2 x WD1500ADFD RAID 0
4 x WD5000AAKS RAID 0+1
Tt Armor Aluminum Tower
Enermax Galaxy 1000W DXX
DELL 2405FPW, 1905FPW
Old July 3, 2007, 03:08 PM
Misoprostol
Guest
Posts: n/a
actually AM2 boards are supposed to support the quad core AMD processors (AM2+) with just a BIOS update.
Old July 3, 2007, 03:50 PM
sswilson's Avatar
Yes, but older boards will not support the newer features (like the ability to control the northbridge freq separately from cpu).
Dell Optiplex 3020 / Intel Core i3 i3-4160 / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Build a new rig newmill CPU's and Motherboards 32 November 12, 2007 07:37 PM
My Next Build. BALISTX CPU's and Motherboards 13 October 4, 2007 11:53 AM
First build. l0ck Troubleshooting 15 July 25, 2007 04:24 AM
New Build and soon to go buy neurobashing CPU's and Motherboards 10 June 20, 2007 09:23 AM
My first ever build, help me out paolo CPU's and Motherboards 31 June 9, 2007 04:04 AM
