Originally Posted by SmogTown I was wondering if the idle temps for my Q9550 were okay. They are 43, 37, 44, 42. It just seems odd that the one core is so much lower than the others. Is this normal? Any help would be greatly appreciated  . |
On both of my Core 2's , I've had up to an 8 degree difference in Temps.
Usually when You load up the cores it evens out.
Run Prime 95 and see if they level off under load.
That is usually normal, what you see as well because even when your comp idles there are processes happening , and one or two of the cores handle those , so naturally they will be higher temp.
Regards,
ST
