Ok thanks, as this is my first build involving liquid, I just want to make sure I do it right. The case will have 6 fans total, and the room temp where I keep my computers (nothing but comps in this room) never gets above 75* F during the day, and they are turned off at night so in the morning it's like 68 in there. Also I some times open the one window I have and use a window fan to blow outside the warm air inside the room if its above 45 outside. The case I have now my temps are listed below:
These are *C
ACPI 29-31
CPU 35-39 (All 4 cores)
HDD 37-40 (5 HDD installed)
Video 63-65 (Nvidia GeForce 9800GTX/9800 GTX+)
These are with 3 fans in a mid tower case (1 case fan, 1 cpu fan, 1 psu fan). I don't overclock my system as I plan on doing that with the liquid. Also I clean my case once a week, as we have alot of inhouse dust even using a filtrete gold filter. My only concern would be I guesss if these are acceptible temps. I am concerned about the video temps, but maybe that will drop once I have the new case and a different card, as I don't have a fan blowing on the video card. But the card does have a fan built in, and it blows hot air out the back. I guess maybe I'm being a little paranoid on this, but with the money that was spent on this new rig (wife almost put me out) I just don't want to mess up my first LC rig. I should have everything put together by fri, if UPS and FedEx don't get lost. I would rather use DHL as they never lost any packages (UPS lost 2 packages from Tiger Direct back in november), but got my fingers crossed. I will let you know what the temps are when it's finally up and running. 1 quick question tho, is there something better out there to monitor the temps, as I use SIW right now.
