-   -   Multi-Threaded Applications (http://www.hardwarecanucks.com/forum/cpus-motherboards/17842-multi-threaded-applications.html)
CMetaphor May 12, 2009 10:23 AM
Handbrake - HandBrake
- Multi-threaded video encoding/recoding application, scalable up to 8 processors.
Cost: Free!
Blender - blender.org - Home
Open-source 3D rendering program, scales up to 8 processors/cores.
Cost: Free!
ffdshow - ffdshow
Can re-encode/upconvert video and audio using up to 8 cores and is included with many streaming media players.
Cost: Free!
WinRAR - WinRAR archiver, a powerful tool to process RAR and ZIP files
Multi-threaded compression/decompression utility.
Cost: $21 USD
Badaboom - badaboomit.com
Video conversion utility that takes advantage of CUDA supporting GPUs (Nvidia 8-series and newer) but does not use the CPU(s).
Cost: $29.99 USD
Mediacoder - MediaCoder - more than a universal audio/video transcoder
More coming! :thumb:
Gellidius May 12, 2009 11:16 AM
WinRar can also be added to the list.
SKYMTL May 12, 2009 11:32 AM
Bah, fddshow is ok but if you want speed; Badaboom is where it's at. I've been using it for the last few months and I'd say it reduces time by about 75% over an overclocked i7 @ 4Ghz. Granted, you need to pay for it but if you do alot of transcoding and have an 8-series or later Nvidia GPU, you need it.
CMetaphor May 12, 2009 11:42 AM
Updated! :thumb:
SKYMTL May 12, 2009 11:50 AM
Sorry, I should have made this clear: to my knowledge, Badaboom CANNOT be used on the CPU.
CMetaphor May 12, 2009 11:56 AM
Awww... looked promising too. I'll Edit...
lowfat May 12, 2009 12:22 PM
Everytime I tried to use Badaboom the video came out was 1-2 FPS during playback. Just butchered the video. It also doesn't give near the control as does Handbrake when it comes to h.264.
EDIT: Handbrake will use 8 threads, however there was no increase in performance with the use of hyperthreading. 4 cores vs 8 threads were nearly identical in encoding time. But with HT enabled it caused the CPU's to run significantly hotter.
SKYMTL May 12, 2009 12:44 PM
Handbrake is a great piece of software.
However, your experiences with Badaboom and interesting. I haven't had an issue with the newest builds.
Chilly May 12, 2009 01:12 PM
I perfer to use custom x264 builds, scales very well, even with hyperthreading! You *can* get much better quality due to the amount of control you have.
x264.tk - Its a command line program but you can use a gui program to control it like meGUI MeGUI - MeWiki
lowfat May 12, 2009 03:47 PM
Ya that looks way confusing. Have you tried handbrake? The advanced options gives a considerable amount of control.
