Old May 8, 2009, 06:33 AM
Default Is it worth the move to I7?
This is my current config:
Mobo: Asus maximus II
CPU: Quad core Q6600 (OC to 3.6)
Ram: 4 gb Mushkin 1066 DDR 2
PSU: Corsair HX 620
GPU: ATI 4850
I want to upgrade to I7, but I'm wondering if its even worth it. Basically the only reason I want to upgrade is just "because" LOL! I'm sure most can relate. But it'll cost alot and I dont know if I'll see a performance increase for the money.
Old May 8, 2009, 06:44 AM
gingerbee's Avatar
the only reason i did was because i do a lot of hd rendering and vm ( i think it is if it will safe you time )
Old May 8, 2009, 06:51 AM
FtGF's Avatar
Depending on your monitor I think the biggest upgrade for you would be the gpu. That is if you're using it for gaming. Then you can see where to go from there.
Fight the Good Fight
Old May 8, 2009, 06:56 AM
Soultribunal's Avatar
Doing it 'Just because' is really not a good reason to jump to the i7 Arena , at least in my opinion.
If however, you are doing massive folding and or applications that require such high multi-threading then sure, by all means do the upgrade.
The Core2's do me just fine for what I need for now, and I am sure the Quad you have running so highly clocked will suffice for a while to come yet.
Regards,
ST
www.realhardwarereviews.com
Old May 8, 2009, 07:01 AM
I just have a 20" monitor. I'm thinking of upgrading that though too! lol
Old May 8, 2009, 07:13 AM
FtGF's Avatar
I just currently upgraded to the i7 myself. Do I need it? Prob not. Other than gaming and folding I don't do anything that would require it. Like any hobby it's expensive but it sure is fun.
What ST said is pretty much spot on and it is definitely not in the bang for buck category. If the upgrade bug has got you and you have the money I doubt anything will stop you though!
Old May 8, 2009, 07:33 AM
"Quote This..."
My 3dmark score jumped from 18200 to 21090 when I went from a p35/q6600@3.6 to an x58/i7920@3.8 with the same gtx260.
stoanee's Avatar
Exactly.
For an immediate performance increase you can upgrade to a better video card.
heatware
Old May 8, 2009, 07:42 AM
"Quote This..."
That's quite an increase I got with my upgrade.
Old May 8, 2009, 07:45 AM
Bahhhh 3Dmark Doesn't matter, its the visions of Protiens dancing in our heads that makes upgrading fun!!!!
ST
Move PSU to Bottom of Case? Scart Case Mods, Worklog & Gallery 4 April 13, 2009 05:40 PM
Move RAID 0 array to new Mobo? Squeetard Storage 1 January 31, 2009 09:33 PM
Cheapest way to move interprovincially? vulcan500rider Off Topic 11 October 5, 2008 10:41 AM
Good news for AMDs move to GDDR5 Hardware Canucks Reviews & Articles from the Web 0 April 28, 2008 10:31 AM
which one, and can i move it ? Unklmo Troubleshooting 4 June 30, 2007 07:23 PM
