  #101 (permalink)
Old May 14, 2009, 12:02 AM
I ran a bit less voltage. But I made the room cool as heck by opening the window for 5 hours with 3C outside. This likely cooled the water as well.
Finally got 222 or 4663 baby.
And boy with the videocards running cooler my score jumped alot.
ORB - Compare
31124.
This is actually the first result I am kind of proud of. Tied for 73 place on hwbot. CPU power does wonders for this benchmark. Cards are still on air.
Same clocks for gpu as other results, just with more cpu power and no power related instability problems.
  #102 (permalink)
Old May 14, 2009, 07:05 AM
HuttFuzz's Avatar
Great!
Core i7 920(D0) @4.0 1.212v | Gigabyte EX58-UD3R | OCZ Gold 3x2GB CL8 | Silverstone FT01-BW | TRUE 1366-RT | eVga GTX275 FTW (713/1512/1260) | Corsair TX850w | Hitachi 500GB | Seagate 7200.11 750GB | Dual Screen (Dell 2208wfp & Viewsonic VP930b)
  #103 (permalink)
Old May 14, 2009, 12:44 PM
Originally Posted by Chris View Post
Yes, it will be interesting to see how vendetta 2 performs with D0, please post temps.
System is up and running. No overclocking yet. May wait awhile before I do. With a few adjustments to bios f5 (nothing on the cpu settings)
core 0 39c
core 1 35c
core 2 38c
core 3 36c
These temps are just with regular use (web browsing, burning dvd at the moment with dvd shrink). Will give temps later when I use orthos.
  #104 (permalink)
Old May 14, 2009, 06:09 PM
Thanks. These temps look great.
  #105 (permalink)
Old May 15, 2009, 10:25 PM
lowfat's Avatar
Got my D0 today finally. Although still waiting on the PSU for the TEC before I'll be throwing it under decent cooling.
Mael
Big Lian Li
Forever Alone
  #106 (permalink)
Old May 16, 2009, 08:20 AM
Here are my temps running Prime 95, 100% load after 5 minutes.
core1 60c
core2 57c
core3 58c
core4 56c
  #107 (permalink)
Old May 16, 2009, 10:17 PM
MpG's Avatar
MpG MpG is offline
What sort of TEC setup are you sticking on it?
  #108 (permalink)
Old May 16, 2009, 10:23 PM
lowfat's Avatar
Going to try a bigger TEC on my Cooler Master V10. Moving from the 70W stock to a 120W @ 13.8V. Which is what I'll be providing it for voltage from a lil' Meanwell AD-155A. Nothing serious as I don't think the V10 will be able to handle much more than 120W anyways.
Mael
Big Lian Li
Forever Alone
  #109 (permalink)
Old May 16, 2009, 10:32 PM
MpG's Avatar
MpG MpG is offline
That's right, I forgot you mentioned that a little bit ago. Kind of curious to see how that works out...
  #110 (permalink)
Old May 21, 2009, 08:42 PM
lowfat's Avatar
Have my D0 system up and running now. Clocks significantly better than the C0 i had before. But the CPU must be warped. There is nearly 10C difference between one core 0 and core 4. Pretty sure I have a pretty good HSF mount.
Mael
Big Lian Li
Forever Alone
