Old April 24, 2009, 06:07 PM
Default Video: How Thermal Compound Spreads
I don't know if anyone has seen these but I found it interesting.
YouTube - How Thermal Compound Spreads
YouTube - How Thermal Compound Spreads (MX-2 Edition)
Old April 24, 2009, 06:41 PM
dataxpert's Avatar
So no one is perfect , we should do a pool, what method are you using ?
Old April 24, 2009, 07:03 PM
Pelt's Avatar
I'm currently using spread with MX-2 with my Domino ALC cooler. I'm getting very good results compared with what I had with the pea method, but that may have been just luck. I noticed with the spread method there was alot of what looked like air bubbles. The pea sized method seemed the best because it was more consistent, fewer if any air bubbles. I've just recieved my Coolit systems TIM and was going to try it out this weekend I think I may try the pea method again.
http://lh4.ggpht.com/nightwarp/R7YQuMGt-JI/AAAAAAAADoQ/KVuthG6qJfE/s400/Supportourtroops-2.jpg
Old April 24, 2009, 07:04 PM
I do the line method but next time i think i'll try the cross method
Old April 24, 2009, 07:08 PM
martin_metal_88's Avatar
Cross for me. Don't realy know why but...
Old April 24, 2009, 07:27 PM
Perineum's Avatar
Cross or pea seems best....
You really need to pay attention to the type and thickness of compound you are using... try to figure out what to do based on your own judgement. Some of those thicker compounds that didn't spread well may finish spreading under heat (and being clamped down) when viscosity goes down.
Old April 24, 2009, 07:43 PM
personally i used the 3 line method first time i mounted my vendetta 2 and then the pea method when i remounted with icd7
Case: HAF 932
CPU: AMD Phenom II 940 3.5ghz w/ OCZ Vendetta 2 Cooler
PSU: OCZ StealthXstream 600w
Mobo: ASUS M3A79-T Deluxe
Memory: 4gb OCZ Platinum 1000mhz ddr2
Graphics: 2x Sapphire 4830s in Crossfire
Keyboard: Logitech G11
Mouse: Logitech G9
HD:WD 640gb Caviar Black + 750gb Seagate
#hardwarecanucks on irc.enterthegame.com
Old April 24, 2009, 07:57 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
No offense to the guy who made these videos but a human pressing on a piece of plastic / acrylic can never duplicate the amount of pressure that a proper heatsink mount will apply to the top of a processor.
Old April 24, 2009, 08:20 PM
belgolas's Avatar
I agree. He can maybe do a 1/4 a normal heatsink will do.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old April 24, 2009, 08:29 PM
dataxpert's Avatar
I'm gone try all those method , make the processor heat a day and came back with the pics of the spread.
Thermal Compound Removal Help no_pulse Guides & How-to's 36 May 7, 2010 10:45 PM
How much thermal compound? 4DoorGTZ Overclocking, Tweaking and Benchmarking 16 April 2, 2009 07:15 PM
Best thermal compound? Cadence Air Cooling 10 December 14, 2008 06:17 PM
Thermal Compound Review no_pulse CPU's and Motherboards 5 July 23, 2008 01:50 PM
change of thermal compound v0maru CPU's and Motherboards 0 March 18, 2008 08:13 AM
