Old April 25, 2009, 05:25 AM
Toronto122's Avatar
Very interesting.
I've used the spread method since I started building computers....no more though, from now on it's the X method for me!!
NZXT Rogue Cube Case
Intel i7 920 @ 3.8 w/Scythe Mugen 2
6 gb Patriot Viper 1600mhz low latency
Asus Rampage II GENE Motherboard
2 x Asus GTX 285 in SLI (710/1617/2700)
1 x 1tb WD Black
3 x WD 640AAKS in RAID 0
Enermax 85-1050 PSU
HP 30" 2560x1600, G19, G7, M-Audio Q40 Headset
Old April 25, 2009, 07:42 AM
dataxpert's Avatar
Totally BS this video, look what happen to a dot after 30 minutes of load. I must say than I preheat the CPU and the paste with a hair dryer, before put the head sink, like I always do , I will try latter without heat
Old April 25, 2009, 10:38 AM
obviously its going to look like theres air bubbles AFTER you remove the cooler, removing that introduces air...
Case: HAF 932
CPU: AMD Phenom II 940 3.5ghz w/ OCZ Vendetta 2 Cooler
PSU: OCZ StealthXstream 600w
Mobo: ASUS M3A79-T Deluxe
Memory: 4gb OCZ Platinum 1000mhz ddr2
Graphics: 2x Sapphire 4830s in Crossfire
Keyboard: Logitech G11
Mouse: Logitech G9
HD:WD 640gb Caviar Black + 750gb Seagate
#hardwarecanucks on irc.enterthegame.com
Old May 3, 2009, 11:11 PM
netforce's Avatar
The video was showing the air bubbles under the plexi before it was removed. Look at the zoom they did after the spread method.
Old May 4, 2009, 02:21 AM
Silvgearx's Avatar
interesting in deed, i just do pea and if cpu stays under 60C for load i know will be fine
Thermal Compound Removal Help no_pulse Guides & How-to's 36 May 7, 2010 10:45 PM
How much thermal compound? 4DoorGTZ Overclocking, Tweaking and Benchmarking 16 April 2, 2009 07:15 PM
Best thermal compound? Cadence Air Cooling 10 December 14, 2008 06:17 PM
Thermal Compound Review no_pulse CPU's and Motherboards 5 July 23, 2008 01:50 PM
change of thermal compound v0maru CPU's and Motherboards 0 March 18, 2008 08:13 AM
