<~----> Motherboard moves a little... ok or not? - Page 3 - Hardware Canucks
  #21 (permalink)
Old April 17, 2009, 07:16 PM
somecanadianguy's Avatar
Ok I fixed the problem.
The screws fit, but they were sticking before they screwed in fully.
I forced them into the spacers (took more force than I would have used with them in the mobo),
then screwed them out and in a bunch of times...
Now they fit fine... motherboard doesn't move anymore.
  #22 (permalink)
Old April 17, 2009, 08:39 PM
gingerbee's Avatar
cool i always dry fit the screws before you out the mb in just for this reason
  #23 (permalink)
Old April 17, 2009, 08:47 PM
I didn't even think to do that...
It's my first build, after all.
So many little things you can't really know until you do it.
  #24 (permalink)
Old April 17, 2009, 08:58 PM
gingerbee's Avatar
you said it. but wasn't it fun
  #25 (permalink)
Old April 19, 2009, 06:12 AM
You said it
Intel moves X58/Nehalem to September! encorp CPU's and Motherboards 3 August 1, 2008 08:19 AM
Motherboard help maurier Troubleshooting 9 May 22, 2008 12:21 PM
New motherboard Infiniti CPU's and Motherboards 6 April 30, 2008 06:55 PM
Looking for a new motherboard JD CPU's and Motherboards 1 December 30, 2007 01:14 AM
Intel moves up schedule for Pentium E2000 and Celeron 400 Babrbarossa Press Releases & Tech News 0 January 30, 2007 06:09 AM
