Old April 17, 2009, 10:56 AM
Chilly's Avatar
Are you using the right screws?
Old April 17, 2009, 11:03 AM
somecanadianguy's Avatar
I'm using the ones with the little lip on them... they came with the case.
Should I be using the other ones?
Old April 17, 2009, 11:07 AM
gingerbee's Avatar
check with the standoffs because i think i know where he's going with this they won't screw down because there too small better to make sure that they screw all the way down in just a standoff to be sure
Old April 17, 2009, 11:08 AM
If that's the case what should I do?
I'll go check now.
Old April 17, 2009, 11:11 AM
Ok... looks like that's what's wrong.
Will it be ok like this for now?
What should I do?
Old April 17, 2009, 11:41 AM
486's Avatar
486 486 is online now
Your MB screws are too long for your MB standoffs, so you tighten the screws in standoffs, but it won't hold the MB.
Fractal Design R5 + Seasonic X-660 650W
Asus X299 TUF Mark 2 + Intel i7-7800X + G.Skill Ripjaws V 3200 8GB x 4
Samsung 950 Pro 512GB + Samsung 850 Pro 512GB + HGST 5400RPM 2TB
Evga GTX 1080 FTW 8GB + BenQ BL3201PH 4K 32"
Old April 17, 2009, 11:42 AM
gingerbee's Avatar
just go to the hardware store and find ones that fit and do the job ( or if your like the rest of us tech people you have bags of these screws lying around )
Old April 17, 2009, 11:43 AM
gingerbee's Avatar
ether that or there the wrong thread size and won't stay tight you hit that nail or screw on the head
  #19 (permalink)
Old April 17, 2009, 03:16 PM
Perineum's Avatar
You will definately want to fix that.... you're going to move your case one day and case flex is going to cause one of those screws to pop out.... if you're lucky they might just cause a short that the power supply handles just fine....
If you're unlucky, well... you'll wish you'd have gone back and done it right
  #20 (permalink)
Old April 17, 2009, 04:52 PM
JD JD is offline
Try the other screws that came with the case? One of them will fit properly.
Intel moves X58/Nehalem to September! encorp CPU's and Motherboards 3 August 1, 2008 08:19 AM
Motherboard help maurier Troubleshooting 9 May 22, 2008 12:21 PM
New motherboard Infiniti CPU's and Motherboards 6 April 30, 2008 06:55 PM
Looking for a new motherboard JD CPU's and Motherboards 1 December 30, 2007 02:14 AM
Intel moves up schedule for Pentium E2000 and Celeron 400 Babrbarossa Press Releases & Tech News 0 January 30, 2007 07:09 AM
