Old April 14, 2009, 05:10 PM
Default E8400 overheat
I recently opened up my tower to clean out my dust vents and make sure everything was still ok. Anyway, in the process I removed my heatsink/fan to clean of some dust and I put it back on, well, not securely apparently. When I turned on my pc I got a CPU overheat message, I didn't think much of it. My PC was on for about an hour and then I was checking a few things in PC wizard and noticed the processor was running at 100 degrees celcius. I turned it off and re-installed the heatsink/fan and cranked up the fan to cool down the processor. Anyway, it runs at 35ish degrees now but I am seeing drastic performance decreases and a lot of freezing/errors. Could my processor be almost toast? and if not now, what would the effect be of it running at such temps for an hour?
http://www.engagepc.com
My blog, all about computers, games and technology
Old April 14, 2009, 05:51 PM
Have you overclocked it much?
Old April 14, 2009, 05:55 PM
Dwayne's Avatar
Sounds like you need to apply some TIM (Thermal Interface Material) or paste. Every heatsink has some TIM on it, if you remove the HSF, which you only should do if you have TIM on hand, is to clean the HS and the CPU with denatured alcohol (the more pure the better) and then reapply the TIM and reseat the HS.
The CPU should throttle when it gets too hot to protect the CPU itself so you may be fine... but you need to find some TIM, you can buy it at most good computer stores.
Dwayne's Rig - Asus Prime Z370-A : i7 8700k : Corsair Vengeance 32 GB DDR4-3000 : Corsair RM650x PSU : Corsair H100i V2: Fractal Design Meshify C : EVGA GTX 1080 :
HTPC - GigaByte H67MA-UD2H : i3 2100 : 8 GB Mushkin Silverline Stiletto : Antec TruPower 550W : : Corsair H100 : Sapphire HD 6670 : Corsair 650D: Kingston 60 GB SSD Boot
Tablet - Samsung Tab A 10.1"
Wife's Rig - MSI GL72M 7RDX
Old April 14, 2009, 06:05 PM
gingerbee's Avatar
pull it off clean it add fresh tim and reseat
Old April 15, 2009, 12:08 PM
Il Duce's Avatar
maybe the pushpins are popping out.
LF--E8400 Gunner86 Buy/Sell & Trade 3 October 19, 2008 03:04 PM
Radeon X1650 Pro overheat Mr. Gruntsworthy Troubleshooting 4 September 29, 2008 10:35 AM
E8400 on ? Rapid-X CPU's and Motherboards 7 May 9, 2008 03:31 PM
are the E8400 out yet? v0maru CPU's and Motherboards 4 March 31, 2008 09:56 AM
