Old June 18, 2007, 11:29 AM
magictorch's Avatar
Level up: 10% Level up: 10% Level up: 10%
Level: 18 - 796 points to level up
Post would a 8800GTS be bottleneck by an opteron 165@2.4ghz
Hi was just wondering if opteron 165@2.4ghz would bottleneck an 8800GTS? with an asus 8n32-sli deluxe and XMS4000PT, OCZ gamextreme 600watt, WD raptor 80gb. cheers, magictorch
Old June 18, 2007, 11:44 AM
Babrbarossa's Avatar
Super Moderator
It would bottleneck it- how much would depend on the program of course, but you would definitely see an improvement. If you're planning on upgrading to a new chipset in the near future, it might be worth going for it, but if you planning on sticking with 939 for some time, you might be better off upgrading your GPU then, depending on how good your current one is- what are you using now?
Building: ASUS P6T X58// i7 920 // SLI evga 260GTX 216SC// 3X2GB Patriot Viper DDR3-1600// Antec TP Quattro 850w // CM Stacker 830
Water Cooling: Apogee GTZ// 2X evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech MCR220 // Swiftech mcp655 pump
HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180
Old June 18, 2007, 12:16 PM
magictorch's Avatar
Default mmm
Well I have a BFG 7950GTOC which is good enough on XP but im thinking of upgrading to VISTA and a solid Dx10 card soon, I was hoping the 939 asus a8n32-SLI and opteron 165 wouldnt hold the 8800GTS up too much. oh well, magictorch
Old June 18, 2007, 12:17 PM
magictorch's Avatar
Default for oprograms i was talking aboput some of the DX10 games
programs-future DX10 games
Old June 18, 2007, 12:42 PM
Super Moderator
Personally, I would stick with the card (and OS) you had until you were ready for a platform upgrade, but other people might disagree.
Old June 18, 2007, 01:02 PM
sswilson's Avatar
Super Moderator
I'm not sure how much of a bottleneck you would see, but you'd end up needing a high end card down the line with or without a full system upgrade, so any gain would still be a gain.
Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW
ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF
Old June 18, 2007, 01:09 PM
Level up: 60% Level up: 60% Level up: 60%
Level: 8 - 72 points to level up
whether to upgrade the card depends on a few things. the games you play, the monitor you have, and your future upgrade plans.
if you play primarily cpu limited games like css on a 19inch lcd at 1280x1024 then no, don't upgrade. if you play stalker on a 24inch lcd then an 8800 is a definite.
i actually just picked up a 8800gtx because i have a 24inch lcd and want to play the new colin mcrae dirt at 1920x1200 with all the eye candy turned on. my x1950xtx couldn't handle it.
ASUS P5Q Deluxe
Intel E6600 @ 3.2GHz w/ 1.5v
2 x 2048MB PC2 8800 GSkill @ 1066MHz (5-5-5-15) w/ 2.1v
Sapphire HD 4870 1GB
SoundBlaster X-Fi Platinum
2 x WD1500ADFD RAID 0
4 x WD5000AAKS RAID 0+1
Tt Armor Aluminum Tower
Enermax Galaxy 1000W DXX
DELL 2405FPW, DELL 1505FPW (sideways)
Old June 18, 2007, 01:39 PM
Misoprostol
Guest
Posts: n/a
I wouldn't worry about that CPU for a while. It's a very solid CPU and honestly you're not going to be processor limited in any game right now.
Old June 18, 2007, 04:58 PM
magictorch's Avatar
Default sounds good
ok thanks for the help guys..this forum is very helpful! im actually just assembling the parts ive sourced at the moment and switching the GPU from my other machine. hopefully it will all work and i get the opteron to around 2.4. Ill see how it holds up with some of the titles this summer and make changes as needed. cheers.
Old June 18, 2007, 05:03 PM
magictorch's Avatar
Default monitor-viewsonic vx2025wm 20" 1680
oh forgot to say i use quite a high resolution although things seem to work well enough with the 7950Gt at the moment..only tried FEAR and halflife 2 though with high settings...my athlon 3200 seems to get very hot though in my crappy emachines so ive decided to build a better system using all the 939 leftovers floating about. The 8800 should make a huge difference with the more recent games.
Intel D975XBX2 and 8800GTX = bottleneck? Dooobie CPU's and Motherboards 11 October 11, 2007 01:46 AM
Opteron Experiment xrmarcis CPU's and Motherboards 8 September 24, 2007 01:44 PM
4Ghz Q6600 Prime stable turtletrax CPU's and Motherboards 14 August 13, 2007 11:05 AM
Gaming Shootout: HD 2900xt vs 8800gts vs 8800gts: X-Bit labs Babrbarossa Reviews & Articles from the Web 12 May 29, 2007 05:08 AM
