Old April 9, 2009, 11:51 AM
gingerbee's Avatar
Default 1366 question
can you run all the new xeons in standard motherboards. i ask because i notice on the box it says design for dual socket any help thank. can't find much
p.s 1366 motherboards for the people who miss the top
Old April 9, 2009, 01:25 PM
SugarJ's Avatar
As far as I can determine, the Xeons are the same chips binned for lower voltage and power output. And there's lots of guys running Xeons on this forum.
Old April 9, 2009, 03:19 PM
gingerbee's Avatar
thats what i thought thank
Old April 9, 2009, 10:27 PM
Chilly's Avatar
You can run the 35xx series in a regular single socket LGA1366 motherboard with no issue, but when it comes to the 55xx series Xeons, I'm not quite sure though I'd assume they would.
35xx series and regular i7's cannot be run/used in dual socket motherboards
55xx series can(well, duh ) be run/used in dual socket motherboards
I suspect that that as long as the motherboard BIOS supports it, the 55xx series will work in a single socket motherboard. Just keep in mind, the 35xx series are priced comparatively with the i7's, the 55xx series are not, I would never consider the 55xx series for a single socket system for that reason alone.
Old April 10, 2009, 06:13 AM
gingerbee's Avatar
i thought that too. if the bios suppports it then good to go but yes the 55XX series says that there for the dual socket 1366 so who knows ( i seen the other post nice ) p.s where did you find info on the 35XX pricing and specs and such thanks chilly ( hope you find work soon )
[FS] Dd mc-tdx (1366) voklskier4452 Buy/Sell & Trade 3 March 31, 2009 09:26 PM
future of socket 1366 gingerbee Rumor Mill 6 February 6, 2009 12:43 AM
Where the $%^$ is my GTZ 1366 adapter?!? Babrbarossa Water Cooling 83 January 31, 2009 12:15 PM
Question about Noctua NH U12P SE 1366 (Nickel plate, installing both fans issue) appplejack Air Cooling 5 January 13, 2009 01:44 PM
Socket 1366 matsta31 Water Cooling 1 November 2, 2008 06:12 PM
