  #21 (permalink)
Old June 19, 2007, 06:02 PM
sswilson's Avatar
Looks like it's going to be a kickass system!!!!
The only small issue I can see left is how important sound is to your gaming experience, and what OS you plan to use.
Hopefully somebody with more knowledge of sound cards (especially the X-Fi line) will step in, but I remember looking into the card you've got listed and there was something about gaming that it didn't play nice with.
The reason I ask about OS is that if it's EAX that the card doesn't do well, AFAIK that's pretty well crippled in Vista anywise so it might not be an issue if you're going to run Vista.
Probably worth looking into, IIRC the Creative site actually states that gamers should consider cards other than the Xtream Audio.
  #22 (permalink)
Old June 19, 2007, 06:14 PM
Supergrover's Avatar
Yup missed that. That sound card lacks bad IMO.
I bought one a couple of months ago to replace my aging audagy mp3, and well the x-fi sounded worse. All the X-FI effects are done in software not hardware, thats not a X-FI chip but rather a re-branded SB live, if I remember right.
R.I.P.
  #23 (permalink)
Old June 19, 2007, 06:22 PM
sswilson's Avatar
If that's the case, and money is a consideration, the better choice would probably be to stick with on-board (ugggg, but it is getting better.... :) ) or maybe finding an Audigy2 card if he/she's stuck on Creative and doesn't want to spend the cash for a full fledged X-Fi.
  #24 (permalink)
Old June 19, 2007, 06:39 PM
Babrbarossa's Avatar
I was wondering how that card worked out for you- at least it was cheap, eh?
psst, wanna see my binder?
  #25 (permalink)
Old June 19, 2007, 06:44 PM
How about This for $77 after rebate, or This for $75, just because Creative is not high on my lists lately
R.I.P.
  #26 (permalink)
Old June 19, 2007, 06:46 PM
I think it was $35 (?) @ the time, not even worth that IMO
R.I.P.
  #27 (permalink)
Old June 19, 2007, 06:57 PM
sswilson's Avatar
As you can see there is a bit of a drop in performance with the Striker 7.1 over the Audigy 2 Platinum. This is primarily due to the fact that the Striker 7.1 uses the CPU to process its audio similar to onboard sound solutions; the Audigy 2 on the other hand has its own processor that handles most of the audio processing. Also take note that the Audigy 2 Platinum is a rather high-end sound card while the Striker 7.1 is more of a mainstream sound card.
I'd be a bit leery of the Striker as it does much of its work through software and that's an issue with Vista's DRM.
It looks like an awesome card for I/O, but I'd do a lot of research on software based Audio cards before picking one up.
My understanding is that anything software which might be user-modified to circumvent (sp?) DRM will be severly crippled under Vista.
  #28 (permalink)
Old June 19, 2007, 07:14 PM
Whatshisface's Avatar
Remember NCIX price matches
But.....
There still is shipping charges
  #29 (permalink)
Old June 19, 2007, 07:18 PM
Also, I want to go with Vista
Major AMD price cuts on July 9th? Babrbarossa Rumor Mill 7 July 9, 2007 11:13 AM
price cuts Unklmo CPU's and Motherboards 12 July 4, 2007 07:23 PM
AMD readies 50% Opteron price cuts Babrbarossa Press Releases & Tech News 6 May 31, 2007 05:31 AM
More AMD price cuts Babrbarossa CPU's and Motherboards 7 April 10, 2007 09:17 PM
More confirmation of AMD price cuts Shadowed Press Releases & Tech News 2 April 10, 2007 08:35 AM
