Old April 3, 2009, 03:23 PM
Delavan's Avatar
Default S775: are Xeons exactly the same as reg. quads?
I was looking at Xeons compared to "regular" desktop Quads...
For the same clock speed and same number of core, same socket, same cache, are they exactly the same except for the price?
Of course, the Xeon, being officially "server" processors are probably more expensive.
If you plan to OC, is there any benefit to choose a XEON? (temperature, voltages, higher binned???)
Please help!
i7 4770K @ 4.0GHz / Corsair H100i / MSI Z97A Gaming 6 / 16GB Kingston Hyper X 1.5V 1600 / MSI GTX1070 FE / Samsung 850 Evo 500gb / Corsair Performance Pro 128GB SSD / Intel 520 120GB SSD / WD Black 640 GB storage / XFX 850 watts Black Edition PSU
Old April 3, 2009, 03:59 PM
Chilly's Avatar
The Xeon S775 3xxx series are usually binned a little better, and tested a little more then their Core 2 Duo brothers, but other than that, they are the same. That doesn't necessarily mean you'll get better overclocks with one, its all luck of the draw.
"Let's face it, we're not changing the world. We're building a product that helps people buy more crap - and watch porn."
Bill Watkins, CEO Seagate Technology
Dual Xeon X5650 @ 4.1GHz | EVGA Classified SR-2
2x4GB G.Skill at 1496MHz (9-9-9-24) | XFX 4890 XXX 1GB at 1000/1000MHz
Intel SSD X25-M 80GB Gen2 | Western Digital 1TB Black | SilverStone Zeus 1200W
Sound Blaster X-Fi XtremeMusic | Sony MDR-V700 | Windows Seven x64
Stuff for Sale! You must buy it, you can't look away!
Old April 3, 2009, 04:37 PM
Ging9's Avatar
I know it's not a quad, but I'm running a Xeon 3110 overclocked to 3.6 in my system...it shows up in CPUID as an e8400...it runs at lower voltage than my previous CPU, and a bit cooler as well. No problems with it whatsoever, and it was actually less expensive than going with the Core2duo when I bought it.
Asus P8P67 Deluxe, i5 2500K, MSI 560 GTX Ti, Corsair 600T, 4X2 GB Kingston 1600, Corsair H60, PC P&C 750.
Old April 3, 2009, 04:48 PM
CanadaRox's Avatar
I used to have an X3350, and its identical to the Q9450. They have a slightly different voltage rating, but they are the same core and overclock about the same.
According to the spec sheets, the only difference besides the voltage rating is "IntelŽ I/OAT" which I don't think is actually anything.
Here are the two spec sheets:
IntelŽ Core?2 Quad Processor Q9450 - SLAWR
IntelŽ XeonŽ Processor X3350 - SLAX2
Project: Black and White
Old April 3, 2009, 05:34 PM
WolfBane's Avatar
I am running a x3110 at 4 gig and no problems low voltage and water cooled . It does pretty good :)
I USE EMT ONLY
Remember... Four boxes keep us free: the soap box, the ballot box, the jury box, and the cartridge box.
Old April 3, 2009, 08:40 PM
Delavan's Avatar
If I look at ASUS's supported CPU list for my P5Q Pro, the XEONs aren't mentioned at all. Wonder if some of you heard of mobos really screwing up with a Xeon?
For now, at least where I look, the prices are the same between Xeons Quads and Quads...
Old April 3, 2009, 08:46 PM
JD JD is offline
They never are since you aren't supposed to run Xeons in desktop boards
But they do normally work and detect fine. My X3350 has no issues in my Maximus/Rampage Formula.
Old April 4, 2009, 01:21 AM
Dashock's Avatar
Yep i was wondering the same but as of now i havent heard anyone run into this issue. Im using my X3110 it runs smooth and cool. currently using the Asus software to underclock pumpin .992 volts for 1.6ghz. The Xeon at the time was also cheaper for me to get as well but i dont regret it i have gotten this baby to almost 5 ghz.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old April 4, 2009, 06:57 AM
Delavan's Avatar
Is the XEON automatically recognized as such by the mobo? What about CPU-z? Any funky "wrong" CPU naming/recognition?
Old April 4, 2009, 12:10 PM
JD JD is offline
None that I'm aware of.
Will prices of core 2 quads go down? squilliam CPU's and Motherboards 13 February 8, 2009 06:40 AM
[WTB] WTB / WTTF: Two Intel Quad-Core Xeons (LGA771) S_G Buy/Sell & Trade 4 January 24, 2009 03:36 AM
45nm Quads? biff CPU's and Motherboards 30 April 13, 2008 11:55 AM
AMD's Barcelona quads are here at NCIX belgolas CPU's and Motherboards 10 September 13, 2007 09:34 PM
AMD Claims that Barcelona whoops QC Xeons: Tech Report Babrbarossa Rumor Mill 2 March 2, 2007 10:34 AM
