Old April 1, 2009, 06:34 PM
Default Motherboard Swap?
Anybody know if you want to test P45 Intel chipset boards if you can swap Gigabyte and Asus without and OS reload?
Just delete the necessaries in device manager first before shutting down and swapping out motherboards?
Cambridge,ON
MSI Z77 M Power/Bios17.12
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel SSD
Win 10 Pro x64
Old April 1, 2009, 06:40 PM
sswilson's Avatar
95% chance that a swap between the same chipset boards will be fine.
Old April 1, 2009, 06:43 PM
Talking
Thanks a lot
Kinda fiigured be okay......but never hurts to ask
I want to play with a couple different boards this weekend
I appreciate the comments,positive or negative
Cambridge,ON
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel SSD
Win 10 Pro x64
Old April 1, 2009, 08:28 PM
Chilly's Avatar
Of course a clean windows install is best, but often times you can swap the motherboard without much issue, even successful cross brand(AMD->Intel) swap aren't unheard of.
Old April 1, 2009, 08:32 PM
Jake_HT's Avatar
I just helped my buddy switch motherboards from p35 to p45 and he's using the same install of windows no problems yet.
http://jakeht.deviantart.com/
Swap similar motherboards JD Troubleshooting 8 March 11, 2009 05:28 PM
Motherboard rev?? bstring CPU's and Motherboards 2 January 12, 2008 02:55 PM
Motherboard and CPU help please vintank CPU's and Motherboards 0 January 8, 2008 09:13 PM
Notebook LCD Swap Stinger Display Units 0 October 6, 2007 06:14 PM
Motherboard swap & FC5 Perrin49 O/S's, Drivers & General Software 4 January 31, 2007 04:10 PM
